uHaul and moving jeep question - JeepForum.com
post #1 of 10 Old 04-19-2004, 12:10 PM Thread Starter
tomwbates
2009 JK Wrangler
I am going to move from Corpus Christi TX to Fort Worth TX ~500 miles....I need to rent a Uhaul and planned to pull my jeep behind it on one of those car carriers. I have 33" tires - anyone used one of these with larger than stock tires - i think the rental place said 265/60R15 are largest - but that may be for their insurance purposes. anyone broke the rules?
'09 JK Unlimited Red Rock
tomwbates is offline
post #2 of 10 Old 04-19-2004, 12:18 PM
tobias94yj
Hillbilly Member
tobias94yj's Avatar
i pulled mine with 31x10.50's, with the rims I have my tires stick out about 3 to 4" from the fender flares. I used u-haul's car carrier where you pull the whole vehicle up on it.
To view the NEW
click here!!!
tobias94yj is offline
post #3 of 10 Old 04-19-2004, 12:25 PM Thread Starter
tomwbates
2009 JK Wrangler
yeah that is what i figured....do you have 15x10" wheels? anyway, from what you remember, do you think there was enough room in the straps to fit a couple more inches of tire? i dont think the width will be an issue - just if i can get it from uhaul without having to show them my jeep!
Thanks, TB
post #4 of 10 Old 04-19-2004, 12:45 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I brought my CJ home on one of those Uhaul tow dollies. The Jeep had an assortment of 33" tires on it at the time. If I remember correctly, it was a tight fit but it worked..
BESRK is offline
post #5 of 10 Old 04-19-2004, 01:36 PM
sonic289
sonic289's Avatar
I just went though this about 2 weeks ago... I have 33's and they did not fit. I was trapped in NJ and had to get back to Michigan. I ended up letting some (ok, at least half) the air out of the tires and had a buddy stand on the tire to compress it some. It was shady as he11 but I got it home without a problem, the trip was almost 700 miles. Just check the straps at every gas/food/bathroom stop.
1991 Wrangler, all black (EDIT: Now Flat Tan), 2.5 liters of raw horsepower, 3.5" Rough Country Lift, 33x12.5" Mud Kings, Black Steel Wheels, Borla Exhaust, Line-X'ed interior, LED taillights, Cavalier front seats, etc. Khaki Jeep Club Memeber No. 2
2003 GMC Sierra 2500HD Extended Cab, Duramax Diesel, Allison Transmission, etc.
sonic289 is offline
post #6 of 10 Old 04-19-2004, 01:41 PM Thread Starter
tomwbates
2009 JK Wrangler
Sonic - thanks for the info - i was thinking that i could let some air out of the tires.. i have never used one of those car carriers before...is there anywhere to attach additional tie downs like more straps, chain etc to secure it more? TB
post #7 of 10 Old 04-19-2004, 01:51 PM
MuddyV8YJ
I haven't ever towed my jeep with wheels on the ground, but i was wondering if you were considering removing the rear/front driveshaft?
'91 YJ. Slightly Modified
'04 WJ. Columbia Edition 4.7 HO. 2" BB, 2" OME. 265/65/16 Icelander MT
MuddyV8YJ is offline
post #8 of 10 Old 04-19-2004, 01:54 PM Thread Starter
tomwbates
2009 JK Wrangler
i was planning on getting the car carrier that loads the entire Jeep up on the trailer - if i get stuck using a car dolly (where the front tires are on the trailer and rears are on pavement), i will have to remove the rear driveshaft.
Thanks, TB
post #9 of 10 Old 04-19-2004, 01:55 PM
sonic289
sonic289's Avatar
Actually there is tow chains attached to the tow dolly itself, I wrapped them around the axle. I was thinking I could take some ratchet straps or a come-along to use as additional back up just in case but I didn't end up doing that. There are additional spots on the dolly where you could potentially attatch additional straps as a 2nd backup to the chains.
Also, to answer your other question I picked up my dolly without the Jeep there so they will not (or in my case did not) need to see the Jeep. It can be your own dirty little secret.
Finally, even though I have a stick I removed my rear drive shaft for towing. You may already be doing it or know how to do it but incase you don't the 4 bolts holding the straps on the u-joints are 5/16 and when you slide the drive shaft out oil will come out of the transfer case... To save this and to prevent oil from dripping out the whole way home I cut the end off of a coke bottle and jammed it on the end of the T-case and duct taped it on until I got home.
sonic289 is offline
post #10 of 10 Old 04-19-2004, 02:17 PM Thread Starter
tomwbates
2009 JK Wrangler
OKay so I have been doing some internet searching and any pros cons out there for flat towing with a tow-bar set up? A while ago I had a custom front bumper made with weld-thru extraction points...i think i can get a tow bar to fit that set-up and just pull it behind the unaul...any input greatly appreciated..TB
Question on moving intake... BWFBezerk TJ Wrangler Technical Forum 16 08-26-2008 09:10 PM
My Jeep is not moving 94YJRUNNER YJ Wrangler Technical Forum 4 06-16-2007 10:51 AM
question about moving fan guard to get to radiator. losfreddy TJ Wrangler Technical Forum 4 03-27-2006 03:27 PM
question about moving threads FifteenCents TJ Wrangler Technical Forum 6 01-11-2006 08:09 PM
Poll: Has Anyone successfully put their Jeep with 35's on a uhaul trailer? Fropleyqk TJ Wrangler Technical Forum 4 02-18-2005 01:36 PM
