Uh oh.. Drive line issues - JeepForum.com
post #1 of 12 Old 08-13-2011, 05:24 PM Thread Starter
Xpress
For some reason I don't think that the ENTIRE drive line is supposed to do this:
Thought it was the muffler again, but went down and all of the exhaust bolts are tight as can be. Pulled on the driveshaft to move myself closer and felt/saw the entire thing move The 2 bolts on the bottom of the skid plate are tight, and even with the nuts off, the section they bolt to doesn't move. What the hell is wrong now???????
All about that unibody life.
Xpress is offline
post #2 of 12 Old 08-13-2011, 05:43 PM
dadstoy
Time to drop the skid and see what broke.
dadstoy is offline
post #3 of 12 Old 08-13-2011, 05:48 PM
MJMPC
Check your notor nounts also/
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #4 of 12 Old 08-13-2011, 05:50 PM
rustybeater
probably just your transmission mount is broken
rustybeater is offline
post #5 of 12 Old 08-13-2011, 06:24 PM Thread Starter
Xpress
WHEW! Big relief.
Turns out there's a bracket that bolts to the bottom of the tranny with 2 bolts. One of those bolts is missing, but the other one was resting inside the skid plate. Off to Home Depot to find another bolt. In the meantime all the parts are soaking with WD-40 to be cleaned.
Also need some threadlocker. Don't think the blue stuff will work?
Xpress is offline
post #6 of 12 Old 08-13-2011, 07:14 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Yep, tranny mount is loose/broken/fubar.
Joe Dillard is offline
post #7 of 12 Old 08-13-2011, 08:35 PM
timatoe
timatoe's Avatar
X'2 on double checking the motor mounts too, if that's been flopping around they very well could be shot.
timatoe is offline
post #8 of 12 Old 08-13-2011, 08:42 PM
Louie4
I also recommend Mean Max's write-up with the aftermarket poly transmission mount.
http://www.jeepforum.com/forum/f12/t...cement-903109/
Oh, and X3 on the motor mounts.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #9 of 12 Old 08-13-2011, 08:51 PM
tobias94yj
Hillbilly Member
tobias94yj's Avatar
Completely agree. I got one a few years ago from MORE and man what a difference. my shifters would move all over the place before especially on acceleration and deceleration and that poly mount fixed that.
To view the NEW
click here!!!
tobias94yj is offline
post #10 of 12 Old 08-13-2011, 09:01 PM Thread Starter
Xpress
Actually, after cleaning everything off, it all looked to be in good condition. Guess the gear oil preserved the rubber somehow?? T-case doesn't touch the skidplate.
Put a ton of high temp threadlocker on the one remaining bolt and stuck it all back together then torqued it down as much as I could. Threw the skidplate back on with a little, *cough* TLC, and then took it for the obligatory test drive. Acceleration and deceleration feels crisp rather than sort of kinda mushy. Motor mounts look like they are in OKAY condition but probably should replace them soon. Not that I'm going to do that anyways, will probably do a 6 cylinder swap or get another Jeep with a 6 in it before I do that..
Xpress is offline
post #11 of 12 Old 08-13-2011, 10:03 PM
TSEJEEPERS
Did you replace the other bolt too?
I would not use red thread locker or any thread locker on that mount.
The case is alum. You will pull the threads out next time you take the bolt out.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #12 of 12 Old 08-13-2011, 11:06 PM Thread Starter
Xpress
^Haven't experienced tearing threads out on aluminum parts, but no it's not red. It's white/high temp, works just like the blue stuff.
The other bolt is still MIA. It will have to do until I can get another one, hopefully tomorrow or monday.
Xpress is offline
possible drive line vibes jeepguyvt TJ Wrangler Technical Forum 9 06-07-2011 05:25 PM
BAD!!! drive line vib. curt7088 TJ Wrangler Technical Forum 27 12-24-2010 02:09 PM
Drive Line Noise when Warmed up from extended drive amytom TJ Wrangler Technical Forum 1 02-26-2009 03:11 PM
Need drive line help please newbs TJ Wrangler Technical Forum 1 09-25-2007 05:26 PM
front drive line issues RED107 TJ Wrangler Technical Forum 4 01-06-2006 06:37 PM
