uh oh...this cant be good - JeepForum.com
post #1 of 7 Old 01-25-2002, 01:36 AM Thread Starter
Atropine
Atropine's Avatar
I was driving down the road last night and I heard a clunk and a bunch of noise. I looked under my Jeep and the rear drive shaft had completely come off on the differential side. I was in the middle of the intersection(in DC) and I needed to get out. I put it in 4WD and got out of the intersection, but I lost the drive shaft completely. Is this fixable? Should I spring for the SYE and CV drive shaft? I really hope I didn't screw up the transfer case. Any help?
93' YJ
00' TJ
02' KJ
04' Dodge Ram
"Jeep mechanic wanted: must be able to put square peg in round hole"
Atropine is offline
post #2 of 7 Old 01-25-2002, 06:11 AM
dartboy
dartboy's Avatar
HAd the same thing happen a few months ago. Except my 4x4 wouldn't engage to get me out of the way. I had to go back and pick up my drive shaft, fell out while pushing Jeep out of the way as I had nothing to tie it up with. Had to replace my slip yolk(it was Junked), and both universals. Everything has been fine since.
Jason
90 YJ...Stock for now.
74 Dodge Dart Sport
dartboy is offline
post #3 of 7 Old 01-25-2002, 06:13 AM
Capa
Would this have anything to do with the lift you put on?
I'm about to purchase the RC lift, that's why I ask.
Capa is offline
post #4 of 7 Old 01-25-2002, 08:33 AM Thread Starter
Atropine
Atropine's Avatar
The bolt that connects the driveshaft yolk to the differential pinion shaft yolk were gone. It looks like I can just replace the bolts and put the old driveshaft back on. My question is: Because I drove with it out I have no idea what position it should be in. I know the driveshaft is balenced, will this mess thigs up even worst if I put it on unbalenced?
I dont think this was a result of the RC lift, It pulled out of the differential side because the bolts were apparently loose.
I do want o get a SYE and CV driveshaft and get rid of the T case drop. Anyone do this? hard?
93' YJ
00' TJ
02' KJ
04' Dodge Ram
Atropine is offline
post #5 of 7 Old 01-25-2002, 09:29 AM
osburn
osburn's Avatar
Yeah, the driveshaft is balanced out of the Jeep, so you can just slide it back in if it's not damaged. Usually when the rear goes like that, it commonly damages one of the yokes. I'd check and make sure a u-joint fits perfectly in the yokes. Ya might need a new yoke. Keep the old one for a spare. A yoke is a very useful spare to carry.
Matt Osburn
Score 1032
osburn is offline
post #6 of 7 Old 01-25-2002, 10:54 AM
Mad Man
I've had the same problem with the bolts from the strap and bolt kit coming loose... I finally just drilled out the yolk and use a normal U-Bolt kit and that solved the problem.
Mad Man
93 YJ "Madness" Flat Fender'd, 4.5" RE Extreme Duty Lift,
3" Body, Rancho 9000's, 35" Goodyears(Cut & Grooved), 4.11's,
Detroit EZ(Rear), Lincoln Locker Front, Manual Vacuum Disconnect, Hurculined Tub, Highlift Jack,
Custom K&N conical setup, Custom Exhaust,
Optima Yellow Top, tons of other stuff
President "Michiana Jeepers"
2000 WJ Laredo Stock Wifes Ride
2001 Dodge Ram 1500 4x4 Quad Cab Tow Vehicle
Mad Man is offline
post #7 of 7 Old 01-25-2002, 11:33 AM
Dan Morera
Dan Morera's Avatar
The same thing happended to me two weeks ago, it's no big deal. When I heard the u-joint go I stopped and took of the driveshaft put the Jeep on 4wd and to it home, I just replaced the u-joint and it works fine. I do agree that you must look carefully for any damage on any of the other joints.
YJ Sahara 88, 258 I6, BA/10
2.5" Susp. Lift (Aprox.), 1" Shackles 31x10.5" Cooper
Dan Morera is offline
TPS good wiring, good Code p0121, low voltage, Possible Causes??? ryankikta TJ Wrangler Technical Forum 2 10-02-2009 07:32 AM
New grears for $700 installed good price or sounds to good to be true? sethco JK Wrangler Technical Forum 24 08-10-2009 12:15 PM
8.8 is a good rear. what is good front axle? need4spd YJ Wrangler Technical Forum 20 09-13-2007 03:01 PM
battery good, starter good, not starting diverman241 YJ Wrangler Technical Forum 8 04-08-2007 12:05 AM
whats the cheapest way to lift,lock,gear and still wheel good and handle good EKUSMC TJ Wrangler Technical Forum 16 03-31-2006 08:35 AM
