Ughh, electrical issue... - JeepForum.com
post #1 of 11 Old 05-18-2010, 06:37 PM Thread Starter
1bad92yj
Well, lemme start off by saying that the jeep had been running fine and still is but... Today I was working on welding something up on the jeep and I didnt have any ground to hook the welder up to so I just took the ground off the battery, but I forgot to take the positive one off the battery. So as I get done just doing a tack weld, I see smoke coming from my hood light. Well, I melted the cord on it, it was aftermarket. Next thing I do is start up my jeep to make sure I didnt fry the harness and it start up fine, all lights work but my radio wont come on now??? So I figure I should probably drive the jeep to make sure its still ok, I get a little down the road and start to turn and it shuts off, all electrical still worked on the inside though, and it started right back up and it did fine the rest of the trip. Is this something I should check into now??
1bad92yj is offline
post #2 of 11 Old 05-18-2010, 06:45 PM
tri486
HMm well first off would be the fuses, then possible u melted a main wire somewhere and it finally broke after driving it. hmm maby your burned out your battery but if you were driving it then it died the engine dosnt rely on the batter once its started..
Running over pot holes is the closest thing to 4x4 in the city....
tri486 is offline
post #3 of 11 Old 05-19-2010, 01:45 PM Thread Starter
1bad92yj
Im not sure if I should be worried about this or not, any other suggestions?
1bad92yj is offline
post #4 of 11 Old 05-19-2010, 01:57 PM
idaholtby
You need to better describe any remaining symptoms that you are suffering from. Are there any codes stored? This kind of amperage shock can reek havoc on the electronics, so yes you should be worried, but try to catalog all of the symptoms that have cropped up and hopefully someone on this board can help to sort them out. There simply is not enough information for anyone to attempt a diagnosis over the web at this point in time.
idaholtby is offline
post #5 of 11 Old 05-19-2010, 02:24 PM Thread Starter
1bad92yj
The only thing that I can tell so far is that the radio and hood light have blown. The engine and all lights are good. Other then the fact that it shutoff while driving. It seems to idle fine and it didnt mess up anymore after it shutoff. I was able to start it up right after it shut off also. How do I get codes from it?
1bad92yj is offline
post #6 of 11 Old 05-19-2010, 02:41 PM
idaholtby
Here is how ... Diagnostic Trouble Codes
post #7 of 11 Old 05-19-2010, 02:46 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Check the fuse for your radio, in fact check all your fuses. You sent voltage (welding) that had to seek ground apparently. The hood light bulb mayjust be blown.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #8 of 11 Old 05-20-2010, 06:27 AM
Que89YJ
We were just discussing that question about disconnecting the battery when you weld. You need to check for faults. Did it start right back up? Radio is probably the fuse common to the light.
Que89YJ is offline
post #9 of 11 Old 05-20-2010, 01:45 PM
warrenpeace24
Like I said in the previous thread. It is always a good idea to completely disconnect the battery. That way nothing like this happens. I know people will argue that it is okay, but I am not a gambling man.
warrenpeace24 is offline
post #10 of 11 Old 05-20-2010, 06:28 PM
K4KAS
What was it you were welding on?
K4KAS is offline
post #11 of 11 Old 05-20-2010, 08:28 PM
TSEJEEPERS
You said you could not find a ground for the welder and took the ground off of the battery.
You did not use the ground for the battery for the ground for the welder did you?
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
Electrical Issue PHXYJ YJ Wrangler Technical Forum 4 12-09-2009 09:43 AM
OME Front Shocks, ughh!! Pipedrummer TJ Wrangler Technical Forum 36 03-04-2007 12:33 PM
Electrical issue LowCash TJ Wrangler Technical Forum 4 01-23-2006 02:35 PM
Electrical issue?? pwoens YJ Wrangler Technical Forum 2 09-15-2005 11:43 PM
Ughh...finally put up the Hard Top... Rommel TJ Wrangler Technical Forum 18 11-01-2004 08:37 AM
