ugh slave cylinder - JeepForum.com
post #1 of 7 Old 02-14-2011, 09:14 PM Thread Starter
jlane0125
ugh slave cylinder
cluch went out on the way to the mud hole, limped it back to my buddies house. bled clutch line. still no pressure.
got under it, figured a new slave cyl, bought a new slave and clutch. took off the bell housing bolts. there was no cover on the flywheel.
the kid that i got it from was literally retarded.
floor jack under bell housing took off the skid plate.
floor jack under the transfer case. drive shafts off.
day three and we havent been able to get the tranny backed off the motor. removed floor cover over shifters and t-case shift lever. it came off easily. tranny shifter refuses to get off. ive pulled and pulled im not sure what else to do. plan on removing the starter tomorrow and hopefully helping out the sit.
im not sure what to do. its just sitting apart. need help.
jlane0125 is offline
post #2 of 7 Old 02-14-2011, 09:40 PM
MJMPC
Is the floor jack still under the T-case?
Did you get the two torx bolts out of the top of the bellhousing?
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #3 of 7 Old 02-14-2011, 09:42 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
You've removed the 4 bolts that attach the shift tower to the tranny & you still can't get the shifter out?
Max
Sent from my ADR6300 using JeepForum
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #4 of 7 Old 02-14-2011, 09:45 PM
88blkyj
those torx up top are a pain in the arse!!
88blkyj is offline
post #5 of 7 Old 02-15-2011, 06:32 AM Thread Starter
jlane0125
bare with me my friend and i havent been around the block too many times. but him and his brother did the same procedure on his 89 and he didnt have too many problems.
t-case is still on the jack.
im gonna go today to autozone and see if i can get some torx bits.
we havent taken any torx out yet, but the trans has slid back a little.
the problem is the shifter in the way. i think the torx are out already not by us.
i started yesterday removing the shift tower and my dad said i should also remove the transfer case. well see today when i get that last nut off the top of the shift tower.
post #6 of 7 Old 02-15-2011, 10:04 AM
bharris68
Daily Driver
They may not be TORX, they look like it, but I have found them to be 12 point sockets instead. Just keep that in mind. I put internal TORX drivers on the top of the bell for the I5 with an AX-15 and wound up taking them back and using the 12 point socket instead.
Your starter probably won't need to come off, though getting it out of the way is helpful.
To get the shifter off - you need to push DOWN on that ring and then ROTATE IT While pushing down some more. Count your bolts off the bell - you should have 6 that matter, as shown here:
If you don't have all 6 that matter - it's not sliding anywhere (Ignore the release arm - different bell with plans for putting the 4 banger against an SM420/Dana18/Warn Overdrive combination.
bharris68 is offline
post #7 of 7 Old 02-19-2011, 02:41 PM Thread Starter
jlane0125
ok got everything off got the whole shebang changed im missing the cover for the flywheel. i dont feel at ease without it. i found it wasnt there after i got under it cleaned everything up lots of brake cleen and a little wd40. made sure to align the pressure plate and cluch put the transmission back in with the transfer still attached all i need to do is flush the tranny and a nice oil change and get the rest ofthat old crap out. i replaced all u joints while i was at it and wire brushed off all the drive shafts. cant wait to see where i end up by the time i leave for boot camp on may 16!!!
help please
BA-10 bad slave cylinder monkeyhouse YJ Wrangler Technical Forum 2 02-09-2010 03:51 PM
How do you know whitch one is bad, Master Cylinder or Slave Cylinder? Morgan_TJ TJ Wrangler Technical Forum 19 08-06-2008 09:00 AM
how to tell if ur slave cylinder is bad? Spigger73 YJ Wrangler Technical Forum 9 01-27-2008 06:14 PM
slave cylinder Spigger73 YJ Wrangler Technical Forum 5 09-13-2007 01:21 PM
Clutch, Master Cylinder, and Slave Cylinder replaced and problem not solved.... loudog3114 TJ Wrangler Technical Forum 7 08-31-2005 08:37 AM
