ubolt eliminator?!?!? - JeepForum.com
post #1 of 17 Old 12-11-2009, 10:00 PM Thread Starter
yjdevin
Is anybody using this kit? I have some ?'s
Treks Offroad Products - 1 1/2-inch UBolt Eliminators
yjdevin is offline
post #2 of 17 Old 12-11-2009, 10:04 PM
simpkijd
simpkijd's Avatar
I was looking at those as well. I have the same questions??? Are those only applicable if you a sprung over?
One day my Jeep will be .....
simpkijd is offline
post #3 of 17 Old 12-11-2009, 10:09 PM
ImpactFabWorks
if you try to use those with a SUA set-up it will lower the jeep
1990 YJ = The Toy/ My Daily Driver
1996 XJ= Wifes Daily Driver
Please fill out your profile, It helps us help you!!!
ImpactFabWorks is offline
post #4 of 17 Old 12-11-2009, 10:12 PM Thread Starter
yjdevin
how will it lower it? i thought it was moving the leafs to the top of the axle?!?!? i'm so confused about these
yjdevin is offline
post #5 of 17 Old 12-11-2009, 10:18 PM
ImpactFabWorks
it will. SIMPKIJD asked if it only works if you are sprung over. if you go SOA with those it should be like 6.5" of lift abouts but if you tried to stay spring under it would lower it 1.5"
post #6 of 17 Old 12-11-2009, 10:19 PM Thread Starter
yjdevin
wait so are they just assuming that your soa already then..
yjdevin is offline
post #7 of 17 Old 12-11-2009, 10:22 PM
ImpactFabWorks
it's not that they are assuming that you are already SOA. It's just designed to be used in a SOA.
post #8 of 17 Old 12-11-2009, 10:23 PM
simpkijd
simpkijd's Avatar
That's the impression I get.
simpkijd is offline
post #9 of 17 Old 12-11-2009, 10:25 PM Thread Starter
yjdevin
but what about this?? because if you used 3 1/2-inch leaves on an soa rig it would be huge so how does this make sense?? >> RE 3 1/2-inch leaves + 1 1/2-inch shackles + 1/2-inch UBolt Eliminators = 5.5-inch net lift
yjdevin is offline
post #10 of 17 Old 12-11-2009, 10:26 PM
ImpactFabWorks
it's talking more in the lines of XJ and MJ users. they are SOA from the factory
post #11 of 17 Old 12-11-2009, 10:29 PM Thread Starter
yjdevin
oh ok that makes sense, i thought that they were using yj's specifically as an example..
yjdevin is offline
post #12 of 17 Old 12-11-2009, 10:51 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
I really need to become a Vendor on here.
I make my own ubolt eliminators & they work excellent.
Joe Dillard is offline
post #13 of 17 Old 12-11-2009, 10:54 PM
ImpactFabWorks
Isn't it amazing how maybe $15 in metal turns into a $140 kit
post #14 of 17 Old 12-11-2009, 11:03 PM
Joe Dillard
Yea, IMHO those items are WAY over priced.
Not to knock a guy for tryin' to make a buck - but yea, those are mighty expensive IMHO.
post #15 of 17 Old 12-11-2009, 11:15 PM
ImpactFabWorks
That's a pretty sweet axle truss you got there also
How to: Vacuum Disco Elimination, Axle Tube Sleeve Fix, ubolt eliminator - 56K beware Joe Dillard YJ Wrangler Technical Forum 48 02-17-2016 04:39 AM
uBolt Replacement Fred007 YJ Wrangler Technical Forum 14 01-08-2010 09:42 AM
d30 ubolt flip? aaronc88 YJ Wrangler Technical Forum 0 03-12-2008 06:12 PM
D30 Ubolt sizes with CAD raStapiMpjaY YJ Wrangler Technical Forum 4 06-06-2007 07:59 PM
8.8 ubolt flip??? zeeman918 YJ Wrangler Technical Forum 7 11-11-2005 11:20 PM
