u-joints - JeepForum.com
post #1 of 7 Old 05-03-2011, 06:28 PM Thread Starter
mudonthetires43
u-joints
i know this has been covered before but i cant find it. im putting a 8.8 in my 94 yj. 8.8 flange is 3.5 inches wide. what u-joint do i need to use my stock driveshaft?
mudonthetires43 is offline
post #2 of 7 Old 05-03-2011, 06:31 PM
Meep97
2009 JK Wrangler
Meep97 is offline
post #3 of 7 Old 05-03-2011, 07:38 PM
Doch80
Should be 1330 I believe. Measure it and let me know.
... find some of my recent threads as I think 94' and 95' is the same.
Doch80 is offline
post #4 of 7 Old 05-03-2011, 07:44 PM
dirtydan69
it depends on which flange you got. most likely you got the 1310 one as the 1330 are less common. what i would do is just see if your u-joint fits. if not you will either need a new rear driveshaft (93 and older wranglers used the smaller 1310 u-joints; so go junk yard hunting) or you can buy a specialized adapter u-joint that has both 1330 and 1310 sizes on it, this may be the cheapest way.
dirtydan69 is offline
post #5 of 7 Old 05-04-2011, 08:15 AM
Doch80
I re-read the first post... which flange are you talking about? The one that attaches to your driveshaft? If that's the one you are refering to then I think you have the 1310 as my 1330 flange is about 4" so I would assume the 3.5" flange is for the 1310. You can get online and order a u-joint that is 1330 on one side and 1310 on the other so you could bolt it up. I think they might also sell them at autozone and the like but can't confirm that.... then buy 2 so you can have one as a spare.
Or you can just buy a 1330 flange. I think mine was $30 a few weeks ago. By the time you buy a "HD" u-joint, you won't spend that much more to get the flange and reuse your u-joint.
Doch80 is offline
post #6 of 7 Old 05-04-2011, 10:45 AM
planedog
I have heard that there is a flange from the Aerostar van that will let you use the orginal u-joint. But that may only apply to pre-94 Wranglers since Jeep changed the u-joint in '94. Might be worth looking into.
planedog is offline
post #7 of 7 Old 05-04-2011, 11:57 AM
1tuffyj
spicer 5-134x 1310 1330 conversion joint. $18 at napa.
stock on a mid 80s dodge or somethin like that so i was told
4yrs of abuse on mine n still goin.
the pressure makes us stronger, the struggle makes us hunger, the hard lesssons make the difference, and the difference makes it worth it.
1tuffyj is offline
RE S/F Joints vs. Currie Johnny Joints RedMountainYJ TJ Wrangler Technical Forum 9 12-12-2007 10:17 PM
RE superflex joints / Currie Johnny Joints HMTwin TJ Wrangler Technical Forum 2 04-24-2007 06:15 PM
Axle u-joints & maybe ball joints. CityJeep90 YJ Wrangler Technical Forum 2 06-04-2006 06:23 PM
Help with front end work... ball joints, u-joints kaffeene YJ Wrangler Technical Forum 5 04-27-2005 09:45 PM
Standard 5-297x U-Joints and the CTM Racing U-Joints MattTheMudder TJ Wrangler Technical Forum 17 02-16-2005 10:05 PM
