U-joint or tranny problem? - JeepForum.com
post #1 of 8 Old 03-31-2010, 10:31 AM Thread Starter
GIJimmay
Hi guys!!! So the other day i was coming up on a stop sign and my jeep made an unnerving thump when i came to a stop and put it in first, after this my jeep would move maybe a quarter inch and freeze (almost like the parking brake was on but it wasn't). Having no way to get it back home i put it in 4 wheel and gave er a little more juice and i broke loose, i drove home with a loud CLUNK CLUNK CLUNK as i went down the road, however the transmssion had no "funny feelings" to it and it sounded like it may have been theu joint any ideas?
GIJimmay is offline
post #2 of 8 Old 03-31-2010, 11:37 AM
cesarcal1
Check your brakes. Something similar happened to me and it ended up being the pads from one of my rear brakes came off the metal part and was locking up one of my rear wheels. Ended up doing both rear drums and new wheel cylinders while I was at it.
cesarcal1 is offline
post #3 of 8 Old 03-31-2010, 11:45 AM
MJMPC
Should not of drove it home.................Crawl under it and check your u-joints.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #4 of 8 Old 03-31-2010, 01:16 PM
Tshark299
Tshark299's Avatar
1987 YJ Wrangler
Well......... it could be a U-joint. Look under your Jeep and see what they look like.
- 4.0L, AX-15, NP231, 4.10s: 3.5" BDS, 31" Muds
- Donated drive train to the YJ, Parted out the rest
- Buick 225 V6: Painless Wiring Harness, Warn Overdrive & Hubs, 2" Lift, 31" Muds
Tshark299 is offline
post #5 of 8 Old 04-05-2010, 12:27 PM Thread Starter
GIJimmay
quick update definatley not u joints lookin at trannt/t case next
GIJimmay is offline
post #6 of 8 Old 04-05-2010, 12:42 PM
jeep795
Check the brakes yet? Cesar might be on to something there. Also an easier check then your transmission, and are you dealing with an auto, manual, 4 cyl or 6. Did this happen while in a turn?
jeep795 is offline
post #7 of 8 Old 04-05-2010, 12:48 PM Thread Starter
GIJimmay
sorry forgot to specify, 4.0 I6 and its a manual, havent had a chance to check the brakes yet, damn that easter weekend!! lol, will get an oppourtunity later this week
GIJimmay is offline
post #8 of 8 Old 04-05-2010, 04:20 PM
Mark05059
I also suggest to check the brakes. The pads that are on the shoes do come loose and would make sense with the big pop that you heard.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
U-joint problem I think. any advice? SHAKEnBLAKE TJ Wrangler Technical Forum 8 05-08-2010 01:57 AM
CV joint problem JayDLT JK Wrangler Technical Forum 10 10-09-2007 02:36 PM
u-joint Problem jeepinjc YJ Wrangler Technical Forum 11 08-28-2007 03:00 PM
U Joint Problem Builder15 TJ Wrangler Technical Forum 3 05-11-2004 11:21 AM
CV joint on a regular tranny Dan Morera YJ Wrangler Technical Forum 3 04-17-2002 03:22 PM
