U Joint sizes - JeepForum.com
post #1 of 5 Old 03-11-2010, 08:47 PM Thread Starter
provinT13
U Joint sizes
I'm looking to get some replacement u joints for both drive shafts and front d-30. I've got a tom woods shaft in the rear to go with my 8.8 and sye. I'm not sure if it's 1330 or 1310. Should I just get the u-joints for the d-30 shaft, or go pull a complete set of shafts from a cherokee (will d-30 shafts from a cherokee work in my d-30)
2 Hands Working Do More Than 1000 Hands Praying
provinT13 is offline
post #2 of 5 Old 03-11-2010, 09:51 PM
JJ-4
JJ-4's Avatar
1987 YJ Wrangler
it should be 1310
87 YJ, 07 JK 5.3 Vortec
Firefighters Jeep Club
p_Club
JJ-4 is offline
post #3 of 5 Old 03-11-2010, 09:58 PM
onlyinayj89
Yeah unless you asked for 1330 from tom woods, its 1310. Older cherokees with the disconnect will be a direct replacement, ( the unit bearing won't work though). Newer ones will have the straight shaft and the bigger 297 u joint. You will need to replace a seal in your pass side diff though for that to work though.
onlyinayj89 is offline
post #4 of 5 Old 03-11-2010, 10:11 PM Thread Starter
provinT13
I might follow stu's write up on the solid shaft swap, those work with both XJ and TJ shafts right?
post #5 of 5 Old 03-11-2010, 11:16 PM
Axl Jack
Yes, both XJ and TJ shafts.
94 YJ w/ stuff. All the work/money I put into it, and the comment I get most is my $20 mod: "Hand throttle?!? That's awesome."
Originally Posted by dmcanally View Post
You know you drive a YJ when it is no longer getting older, but slowly becoming brand new part by part.
Axl Jack is offline
cv joint rebuild, correct placement for greasable u joint zerk fitting rutacon05 TJ Wrangler Technical Forum 5 10-31-2012 08:22 AM
Heim joint suspension switching to jonny joint or comperable sct11 TJ Wrangler Technical Forum 2 12-02-2009 05:32 PM
Dana 30 ball joint sizes? KrisMnttopTJ TJ Wrangler Technical Forum 1 06-11-2009 06:56 PM
need help with u-joint sizes Piratejonh TJ Wrangler Technical Forum 4 09-17-2008 08:57 PM
Lift Control Arms: Ball joint vs Heim Joint types? CB3 TJ Wrangler Technical Forum 5 04-21-2007 12:27 AM
