U Joint retainer clip removal help - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > U Joint retainer clip removal help
Amsteel Blue Synthetic Winch line Free ShippingRing & Pinion's, Lockers, 4340 Axles, Install Kits, BaRaceline/Allied Wheels on Sale NOW !
Unread 07-27-2009, 02:09 PM   #1
YJames90
aka Jamesx2
YJames90's Avatar
I have a driveshaft u joint that I have to remove but one end is held in by a clip that is just a C and no place to put plyers on.
All I can do is just make it spin in the groove.
I was thinking weld a bump of weld onto each end and grab it with the plyers.
Screw drives and hammers are not working.
Any suggustions?
Originally Posted by timatoe View Post
SOA is completely out of you're league at this point.
Originally Posted by JeeperDon View Post
Some Jeepers can do some of the mods some of the time, but not all Jeepers can do all the mods all the time. :cheers2:
My 2.5 to 4.3 swap thread
http://www.jeepforum.com/forum/f12/4...begun-1237704/
YJames90 is offline   Reply With Quote
Unread 07-27-2009, 02:45 PM   #2
Leans93
She's my density...
Leans93's Avatar
If the other side's clip is still good I would remove it and force the u joint out that end giving you room to grab the broken clip with a good pair of pliers and work it out that way.
M.F. Leans
93' YJ 4.0L AX-15, 4" Pro Comp lift, 3/4" shackles, 1" BL, 33x12.5x15 BGF MT's, and some other stuff
Originally Posted by Mike Jones
Catch me on the highway or about to tear the mall up.
Leans93 is offline   Reply With Quote
Unread 07-27-2009, 03:05 PM   #3
yjjeepster
Hit it with an air chisel. It will pop right off.
95 yj 4.0 4" rc 33's. 8.8 rr, lockrights with 4.88's front and rear. warn xd9000i. tag, warn, hella, dynomax, optima
yjjeepster is offline   Reply With Quote
Unread 07-27-2009, 07:04 PM   #4
YJames90
aka Jamesx2
YJames90's Avatar
I got it with welding a spot on the end then wacking it with a hammer
