U Joint Replacement - JeepForum.com
post #1 of 7 Old 05-24-2006, 01:21 PM Thread Starter
DirtyDog
U Joint Replacement
Anybody know of a good write-up on replacing U Joints? I am getting alot of rattling under my 88 YJ and from all I've read on the forums, it seems that the U-joint is the culprit. Also, can anybody tell me how much mechanical ability one would need to change a U-Joint, and what tools would be required? I checked with the mechanic and he told me the would charge around 100-150 dollars, so if possible I would like to do the work myself and save some money. I have a Chilton's manual but the write up in there seemed to require prior knowledge of U-joint replacement to get started. Thanks for the help.
DirtyDog is offline
post #2 of 7 Old 05-24-2006, 01:22 PM
TellyDSP
Poland and PPV!!!!
On the axles or driveshafts? The process is similar, but the axles are a bigger PITA.
Here's a writeup. Since I dont have a vise, I used a BFH to smack the small socket.
http://www.popularmechanics.com/auto...n/1272541.html
on the axles, you'll have to first removes them from the tubes. I know there's a writeup somewhere, but my boss is coming.
-Craig-
95 Rio Grande
07 Ram 1500
Originally Posted by Jeeples
n00bs bashing n00bs, it's a pitifull thing.
TellyDSP is offline
post #3 of 7 Old 05-24-2006, 01:32 PM
92 Green YJ
92 Green YJ's Avatar
its fairly simple really, especially on the driveshaft. for tools you need a 7mm (as i recall) socket to remove the four bolts that are on the u-joint straps on the rear yoke. then slide the driveshaft out (Im assuming a stock driveshaft). now you need a pair of needle nose pliers to remove the retaining clips that hold the caps in place. there are two on the axle end, and four on the t-case end. Now, to remove the joints from the shaft, the best thing is a u-joint tool. it looks like a bog c-clamp, harbor freight has them for about 35 bucks. if you dont have that, a BFH and a punch can be used for removal. you need to pound the joint through enough to remove one of the bearing caps, then pound it the other way and pull the other cap, then the u-joint should come right out.
to re-install the new ones, pull the caps off, minding the needle bearings stay in place. slide the caps in as far as you can, put the u-joint in, then use a shop vice to press the caps in, make sure you dont knock the needle bearings out of place. then use the u-joint tool to press them in the rest of the way. use a needle nose to install the new retaining clips, and you are done. grease em up and put the shaft back in.
your Haynes manual should detail this procedure as well
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #4 of 7 Old 05-24-2006, 07:34 PM Thread Starter
DirtyDog
I am pretty sure its on the drive shaft, as most of the clanking and rattling seems to be coming from under the jeep behind the front seats. I got under the Jeep a while ago and checked it out, but I really don't know if there is a way to check and see if if the U joints are really whats damaged. Any ideas on how I could check this? Thanks for the responses so far.
DirtyDog is offline
post #5 of 7 Old 05-24-2006, 07:54 PM
Johnny World
Johnny World's Avatar
Here you go. I had the same problem and got good answers.
http://www.jeepforum.com/forum/f12/look-what-i-discovered-today-pics-clips-269248/
And as for not knowing how to change a u-joint, don't worry, I didn't even know what a u-joint was. but reparing it myself was probably the smoothest repair i've done on my YJ to date.
I used this write up to install my new u-joints.
http://www.pirate4x4.com/tech/ujoint_install/
oh yeah, if your replacing one u-joint, might as well replace the other. (rear driveshaft has 2).
'02 WJ, Laredo Special Edition, 4.0L I6
Johnny World is offline
post #6 of 7 Old 05-24-2006, 08:57 PM
ragtopkid
Front has 2 u loints also, real easy to do with my 20 ton shop press, but I have done the socket/ BFH route and big vise route also. I am just at that point in my life that I can afford the correct tools to do the job as easy as possible.
ragtopkid is offline
post #7 of 7 Old 05-24-2006, 10:50 PM
LOCKED UP
Senior Web Wheeler
LOCKED UP's Avatar
2006 XK Commander
http://www.delta4x4club.com/TECH/UNIVERSAL/UJOINTS.php
... an no sidewindin' bushwackin', hornswagglin' cracker croaker is gonna rouin me bishen cutter.
LOCKED UP is offline
U joint replacement zeke6785 YJ Wrangler Technical Forum 1 12-16-2008 10:45 PM
Replacement U-joint stedwest TJ Wrangler Technical Forum 6 03-17-2008 01:26 AM
U-Joint Replacement rjt36 TJ Wrangler Technical Forum 14 06-22-2007 02:15 PM
U-Joint Replacement Optik45 TJ Wrangler Technical Forum 4 09-09-2004 12:30 PM
cv joint replacement? T-Jeeper-J TJ Wrangler Technical Forum 1 04-04-2004 04:26 PM
