u-joint - JeepForum.com
post #1 of 2 Old 01-02-2012, 11:46 AM Thread Starter
zte87
GIVE IT THE ONION
zte87's Avatar
u-joint
So I needing to replace my axle shaft ujoints and wanted to know what it the best ujoint I can buy that will still fit in my stock axle shafts (93,2.5 non abs) also where can I find the best deals on outer door handles,and the little rods that run the door locks and handle for full steel doors my drivers door outside handle is shot and will not open the door any more. Thanks in advance
zte87 is offline
post #2 of 2 Old 01-02-2012, 11:52 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
The best quality ujoint? For a 260? That's a little unnecessary seeing that the next step up is a 297/760 and the cheapest one of those is still beefier than the more expensive 260's.
Get Dana Spicer parts if you're looking for quality. If you're looking for something that will hold up a little longer get some shafts out of a '95 and use the larger ujoint. There is no send in putting CTM's in stock shafts.
As for door parts, I haven't the slightest clue. I just wanted to help out with the ujoint situation.
Luck Favours The Prepared
Anticanman is offline
cv joint rebuild, correct placement for greasable u joint zerk fitting rutacon05 TJ Wrangler Technical Forum 5 10-31-2012 08:22 AM
Shop convienced me to drop CV Joint in Frnt DS for a single u joint iceman123187 TJ Wrangler Technical Forum 26 03-19-2010 09:52 PM
Heim joint suspension switching to jonny joint or comperable sct11 TJ Wrangler Technical Forum 2 12-02-2009 05:32 PM
Ball, joint, U-joint, control arms? Clunking noise. FritzTJ TJ Wrangler Technical Forum 11 09-18-2009 10:59 AM
Lift Control Arms: Ball joint vs Heim Joint types? CB3 TJ Wrangler Technical Forum 5 04-21-2007 12:27 AM
