U-Bolt like knife on Axle - Page 2 - JeepForum.com
post #16 of 41 Old 10-07-2013, 07:36 PM
ashland82391
Originally Posted by mcnallysport View Post
I opened up the axle case to find info on my gear ratio. It's a 3.07 (43-13). Initial inspection has one of the spider gears pitted, but only one.
It only takes one. Id get rid of it before you have real problems...
ashland82391 is offline
post #17 of 41 Old 10-07-2013, 09:43 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
3.07 Dana 35's are cheap. AmmitOsiris will have one available once he gets off his behind and swaps the rear end I arranged for him.
Luck Favours The Prepared
Anticanman is offline
post #18 of 41 Old 10-08-2013, 03:42 PM
flipit
I got a 35 I'd be willing to part with. I can bring it over to Pleasant Hill sometime. I'm not sure the gears, I can open it if you'd like. I pulled it off my jeep a year ago and it hasn't moved much since. I'm not sure the condition, I figured I'd look at it more once i planned to sell it along with the front, as like these guys are saying, i moved up in size. but yeah, if you're interested in one, just PM me, and I'll take pictures of whatever you want to see before i lug it out there.
flipit is offline
post #19 of 41 Old 10-08-2013, 05:14 PM
AmmitOsiris
AmmitOsiris's Avatar
Well what engine do you have?
Sent from Peggy's office
AmmitOsiris is offline
post #20 of 41 Old 10-08-2013, 06:28 PM
flipit
Originally Posted by ammitosiris View Post
well what engine do you have?
5.0
Project #1- http://www.jeepforum.com/forum/f12/5-0-yj-right-way-1799609/
flipit is offline
post #21 of 41 Old 10-08-2013, 06:34 PM
ashland82391
Originally Posted by flipit View Post
5.0
I think he meant stock engine
post #22 of 41 Old 10-08-2013, 07:16 PM
flipit
If the engine isn't stock, I wouldn't expect the gears to be stock. But the PO told me it originally came with the 2.5 I4
flipit is offline
post #23 of 41 Old 10-08-2013, 07:19 PM
squarelite
Most likely the u bolts were loose for years and just wore through the tubes.
When you need new u bolts, swing by Dentoni's at 5650 imhoff in concord. I worked for the company for years, then I left, and a long story short I am back for the mean time. I work out of the Stockton area and Bay Area. We can make u bolts on the spot in concord, and if we don't have the material, we will have them read for pickup the next day.
squarelite is offline
post #24 of 41 Old 10-08-2013, 07:20 PM
ashland82391
In that case it has 4.10 gears which is the most desirable stock gearing in a Jeep. So the PO very well may have left them.
post #25 of 41 Old 10-08-2013, 07:36 PM
flipit
Well hey even better. Not to criticize the PO, but he was a madman, so I would not be surprised if he tossed in a random gearing, but if they are desirable then he probably left them in. again, I figured I'd check them out once I was done with their replacements, which should be this month, but hey, if a fellow JFer needs one, I can at last see if I got what they need.
flipit is offline
post #26 of 41 Old 10-08-2013, 08:47 PM Thread Starter
mcnallysport
So, back at the ranch, I wanted to see if that U-bolt that cut through the housing actually started in on the semi-floating axle. So I went to remove the spider gears (one pitted) and quickly realized the last guy in this differential really didn't want anyone back... He used a spring clip to retain the spider shaft instead of the stock retaining bolt (which probably have a history of crapping out). Any ideas on how to pull this out, let me know, perhaps put some threads in it then pull it w/ a bolt, but there is so little room...
I should "PM" AmmitOsiris as he suggested, but I'm such a rookie on this site I don't know what "PM" stands for...
Tech data- Engine 4.2L with 240KMiles, (did a compression check to see how much to spend on an axle). Need to spend $ on engine so the 8.8 will have to wait awhile, looking for the 3.07 (43-14) dana 35.
mcnallysport is offline
post #27 of 41 Old 10-08-2013, 08:52 PM
SeanB95YJ
PM = private message
if you click on his name, a menu opens up.... one of the options is "send a private message to ______" whoever it is you clicked on
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #28 of 41 Old 10-08-2013, 08:54 PM
flipit
I should "PM" AmmitOsiris as he suggested, but I'm such a rookie on this site I don't know what "PM" stands for....
Private message.
Ah, my phone is slow out here, you got it
flipit is offline
post #29 of 41 Old 10-08-2013, 09:41 PM Thread Starter
mcnallysport
Thanks for the "driving" instructions.
post #30 of 41 Old 10-08-2013, 10:59 PM
imstillatwork
Craziness! I'm guess the ubolt is stretched more than the tube is dug out? love to see 'after' pics when you take it apart
imstillatwork is offline
