Two questions. - JeepForum.com
post #1 of 14 Old 02-11-2013, 06:58 PM Thread Starter
dakota123
Two questions.
My gas oil and battery gauges dont light up anymore what do i do to fix it? and my right turn signal arrow is bold not flashing and is always on (only on inside) when i turn on my jeep. Anyone know what that would be from? Thanks
dakota123 is offline
post #2 of 14 Old 02-11-2013, 07:06 PM
jcmooreusmc
Not being a smart ***, but did you check the bulbs and fuses? I replaced all of my dash lights w/ some LEDs I got off of eBay recently. Costs about $10 to do them all.
jcmooreusmc is offline
post #3 of 14 Old 02-11-2013, 07:12 PM
Chrisnvegas
INFIDEL
Chrisnvegas's Avatar
Do the LED's dim with the dimmer? I still have the regular dash lights and they are way too bright when out in the desert.
"Go to Heaven for the climate, Hell for the company." Mark Twain
Chrisnvegas is offline
post #4 of 14 Old 02-11-2013, 07:19 PM
jcmooreusmc
Had to run out to the Jeep to check, but yes the lighting can be reduced w/ the dimmer switch..........they are LEDs, so they are a good bit brighter than stock ones. Makes it look newer in my opinion.
post #5 of 14 Old 02-11-2013, 07:24 PM
Chrisnvegas
INFIDEL
Great, thanks. My next project. (If nothing breaks this weekend!)
post #6 of 14 Old 02-12-2013, 03:49 PM Thread Starter
dakota123
Havent checked the fuses yet. I will start with that haha But about the led lights was it a kit specifically for the yj or did you just rig some up?
post #7 of 14 Old 02-12-2013, 04:52 PM
jcmooreusmc
Here ya go:
http://www.ebay.com/itm/120960153862...84.m1497.l2649
post #8 of 14 Old 02-12-2013, 07:13 PM
Mrjones
is there a write up on how to do that? Was it a challenge or easy?
Mrjones is offline
post #9 of 14 Old 02-12-2013, 08:50 PM
jcmooreusmc
Really easy swap. Takes a phillips head screwdriver and about 10 minutes. Just pop the guages out and swap the bulbs. They will go in 2 ways, but will only come on if inserted the correct way. Easy fix would be put one in and turn on your lights. If it doesn't light up, then just pull it out and rotate it.
post #10 of 14 Old 02-12-2013, 09:25 PM Thread Starter
dakota123
Thanks i will order those now. I checked my fuses and it wasnt the fuse so maybe the wireing got messed up somehow. Im going to try and pull it off and see whats back there
post #11 of 14 Old 02-13-2013, 09:25 AM
Que89YJ
Que89YJ is online now
post #12 of 14 Old 02-13-2013, 09:51 AM
Mrjones
Are there eight lights in the dash over all?
Mrjones is offline
post #13 of 14 Old 02-13-2013, 06:10 PM
jcmooreusmc
I do believe that there are 10 including the tach and speedo. I had exactly enough in the kit to replace all of them.
post #14 of 14 Old 02-13-2013, 06:43 PM
Mrjones
Just ordered a set off Amazon 15$ after shipping im excited..... Think we can get a night pic?
Mrjones is offline
