Turning signals- Almost Fixed... just... - JeepForum.com
post #1 of 32 Old 06-12-2013, 07:11 PM Thread Starter
Prspallone
1982 CJ7
So I have had a bunch of problems with my turning signals. First I had a short blowing fuses: Fixed it, Then the signals stayed solid: Fixed it, Now I'm trying to figure this last thing. If I turn the headlights on the rear signals blink but the front ones do not, same thing with the hazards if I turn on the headlights the taillights blink but the front lights do not. Any ideas?
Prspallone is offline
post #2 of 32 Old 06-13-2013, 06:34 AM
waif69
1987 YJ Wrangler
Good luck! I had a similar issue and wound up taking it to someone to fix.
waif69 is offline
post #3 of 32 Old 06-13-2013, 10:15 AM Thread Starter
Prspallone
1982 CJ7
Did they tell you what was going on? May I ask what they charged you?
post #4 of 32 Old 06-13-2013, 10:31 AM
ki4cye
Sounds like it could be a bad ground on the tail lights. Witch side of the bulb is flashing when you turn on headlights, short side or long side. What happens when you turn on blinker or hazzard lights.
Sent from here to there using JeepForum
ki4cye is offline
post #5 of 32 Old 06-14-2013, 10:08 AM Thread Starter
Prspallone
1982 CJ7
That might be true, I was having grounding problems early so maybe there is still a very slight short. Hazard lights work as long as I don't have headlights on.
post #6 of 32 Old 06-14-2013, 10:44 AM
Handsomefloyd
I had similar problems when I changed my dash wiring harnesses. Insulation had worn away on one of the wires running to the back of the jeep and was grounding out against the tub. Found it, covered it with electrical tape, and bingo - problem solved!
My Jeep build -
Handsomefloyd is offline
post #7 of 32 Old 06-14-2013, 11:30 AM Thread Starter
Prspallone
1982 CJ7
Hmmm well I guess its time to bust out the electrical tape. I'll let you all know how it goes, thanks for the really!
post #8 of 32 Old 06-14-2013, 05:05 PM
ki4cye
Does the indicator lights in the dash flash when hazard or blinkers are on
ki4cye is offline
post #9 of 32 Old 06-14-2013, 05:05 PM
ki4cye
Also what year is your yj
ki4cye is offline
post #10 of 32 Old 06-14-2013, 05:16 PM Thread Starter
Prspallone
1982 CJ7
Its a 95. I don't know why I didn't also state that I have LED taillights and a CJ frontend conversion.
post #11 of 32 Old 06-14-2013, 05:17 PM
ki4cye
Do the front blinkers and indicators stay on with headlights and blinkers on. Do the front parking lights come on with headlights and blinkers on.
ki4cye is offline
post #12 of 32 Old 06-14-2013, 05:19 PM
ki4cye
The front and rear blinker and hazard lights are separated in the blinker switch
ki4cye is offline
post #13 of 32 Old 06-14-2013, 05:22 PM
ki4cye
Looking at the wiring schematics the only thing common between the front turn signal and parking light is the ground.
ki4cye is offline
post #14 of 32 Old 06-14-2013, 05:31 PM
ki4cye
Try taking the bulbs out one at a time and see if the other side works properly.
ki4cye is offline
post #15 of 32 Old 06-14-2013, 05:43 PM
ki4cye
I went out and looked at mine(1990 but should be close to same) looks like headlight parking light and blinker share the same ground and spliced in harness for each side. Have you checked the ground connector in the bulb socket. If you turn on headlights and hazard lights and pull one bulb at a time and it works properly with one of them out that will be the problem side.
ki4cye is offline
