-   -   Turning signals- Almost Fixed... just... (http://www.jeepforum.com/forum/f12/turning-signals-almost-fixed-just-1535759/)
Prspallone 06-12-2013 07:11 PM
So I have had a bunch of problems with my turning signals. First I had a short blowing fuses: Fixed it, Then the signals stayed solid: Fixed it, Now I'm trying to figure this last thing. If I turn the headlights on the rear signals blink but the front ones do not, same thing with the hazards if I turn on the headlights the taillights blink but the front lights do not. Any ideas? :confused:
waif69 06-13-2013 06:34 AM
Good luck! I had a similar issue and wound up taking it to someone to fix.
Prspallone 06-13-2013 10:15 AM
Did they tell you what was going on? May I ask what they charged you?
ki4cye 06-13-2013 10:31 AM
81 Attachment(s)
Sounds like it could be a bad ground on the tail lights. Witch side of the bulb is flashing when you turn on headlights, short side or long side. What happens when you turn on blinker or hazzard lights.
Sent from here to there using JeepForum
Prspallone 06-14-2013 10:08 AM
That might be true, I was having grounding problems early so maybe there is still a very slight short. Hazard lights work as long as I don't have headlights on.
Handsomefloyd 06-14-2013 10:44 AM
I had similar problems when I changed my dash wiring harnesses. Insulation had worn away on one of the wires running to the back of the jeep and was grounding out against the tub. Found it, covered it with electrical tape, and bingo - problem solved!
Prspallone 06-14-2013 11:30 AM
Hmmm well I guess its time to bust out the electrical tape. I'll let you all know how it goes, thanks for the really!
ki4cye 06-14-2013 05:05 PM
81 Attachment(s)
Does the indicator lights in the dash flash when hazard or blinkers are on
81 Attachment(s)
Also what year is your yj
Prspallone 06-14-2013 05:16 PM
Its a 95. I don't know why I didn't also state that I have LED taillights and a CJ frontend conversion.
ki4cye 06-14-2013 05:17 PM
81 Attachment(s)
Do the front blinkers and indicators stay on with headlights and blinkers on. Do the front parking lights come on with headlights and blinkers on.
ki4cye 06-14-2013 05:19 PM
81 Attachment(s)
The front and rear blinker and hazard lights are separated in the blinker switch
ki4cye 06-14-2013 05:22 PM
81 Attachment(s)
Looking at the wiring schematics the only thing common between the front turn signal and parking light is the ground.
ki4cye 06-14-2013 05:31 PM
81 Attachment(s)
Try taking the bulbs out one at a time and see if the other side works properly.
ki4cye 06-14-2013 05:43 PM
81 Attachment(s)
I went out and looked at mine(1990 but should be close to same) looks like headlight parking light and blinker share the same ground and spliced in harness for each side. Have you checked the ground connector in the bulb socket. If you turn on headlights and hazard lights and pull one bulb at a time and it works properly with one of them out that will be the problem side.
The time now is 03:21 AM.
