Turning and Idling - JeepForum.com
post #1 of 2 Old 05-14-2002, 08:35 AM Thread Starter
SnowMan
Turning and Idling
Does anyone out there have the problem with there YJ that when your say paralell parking the motor really stagers to a low idle then jumps back to normal with the clutch in, seems to always happen when I turn the wheels to the right (most of the time) at a slow speed. Thought maybe a pinched vacuum line? Just seeing if anyone out there has this happen to them and has fixed it or it is just a thing that happens. Also wondering if this could be linked to my poor idle speed when the engine is warm.
Is that you John Wayne, is this me!
SnowMan is offline
post #2 of 2 Old 05-14-2002, 08:45 AM
rick_chicago
I'm having the very same problem.
Logic would have you start with the steering system, as it seems turning the wheel loads up the power steering. I've replaced the original PS pump, as well as the belts. Next up will be the pressure and return lines that lead from the pump to the gear (I sure wish I'd have done that when I had the pump off!). After that, I'm not sure what to check.
I'd also love to hear any other theories.
89 YJ 2.5L 5-Spd
rick_chicago is offline
idling low mikeym41240 TJ Wrangler Technical Forum 13 07-31-2009 05:37 PM
Idling issue on a 4.0L Please Help! bigevilalien TJ Wrangler Technical Forum 15 06-14-2008 07:59 PM
High Idling Roman68 TJ Wrangler Technical Forum 4 10-13-2005 02:51 PM
Rough idling, dying while idling...tranny problem? MissLarramendy TJ Wrangler Technical Forum 7 07-25-2004 04:20 PM
