Turn Singal Madness - JeepForum.com
post #1 of 5 Old 02-09-2005, 01:59 PM Thread Starter
rick95
Turn Singal Madness
heres the problem...my left directional works great. my right directional does not for some reason, It makes the clicking noise but the lights dont flash.
When headlights are on : park light works, right directional does not, rear light works
When the headlights are off : park light does not work, directional does work, rear does work
in both cases, no lights are blinking...is this a problem with the turn singal lever on the steering wheel or something else Help PLease!
Also. when i turn my headlights on, the right turn singal is always on on the dash (but doesnt blink, it just lights up)
rick95 is offline
post #2 of 5 Old 02-09-2005, 02:25 PM
Yoink
This indicates you probably have a broken light somewhere. Go along your right side and check for any lights that are out or broken. I'll bet one of them is dead somewhere.
'95 YJ SE - I6 4.0L, 2" BDS, 1" Shackle Lift, 2.5" BL, 31X10.50 A/T's, Herculined (Work In Progress)
AIM - XDemiG0DX42
Yoink is offline
post #3 of 5 Old 02-10-2005, 01:11 PM
nola3133
Same Problem
I have the same type of problem with my turn signal too. The left works fine but when I try the left the light turns in the dash but does not blink. Also, none of the lights on the right side of the jeep blink when its switched to the right. Let me know if you find out more on the problem.
nola3133 is offline
post #4 of 5 Old 02-10-2005, 02:31 PM
AFjeep
Replace the bulbs. Check the cheapest and easiest first...
95 YJ, 2.5L, flowmaster exhaust, pretty much stock. Future upgrades; 2.5" RE lift, 31" tires, Posi-Lock, cheap winch. Anyone wishing to donate funds, please PM me!
AFjeep is offline
post #5 of 5 Old 02-10-2005, 02:41 PM
teqmod
teqmod's Avatar
Sounds like you may have a ground problem. Check your various grounds and clean any rusted oned as best possible
I don't care if you lick windows, take the special bus or occasionally pee on yourself...
You hang in there sunshine, you're freaking special.
91/93 YJ's merged 4.0L ax-15 8.8 w/Detroit TB spacer SOA SuperShortSYE
01 Cherokee stock
03 Yamaha R1 "Couldn't catch it if you tried"
teqmod is offline
Turn singal does not turn off when I turn left. MWguy101 YJ Wrangler Technical Forum 31 02-14-2010 04:21 PM
Vacuum Line Madness DThomas YJ Wrangler Technical Forum 8 10-04-2008 05:51 AM
Peugeot Madness sykojeep YJ Wrangler Technical Forum 20 06-30-2008 09:00 PM
Exhaust Header Madness!! bamato YJ Wrangler Technical Forum 9 03-14-2006 09:00 PM
Gas gauge madness, can dealer fix? AgentZed TJ Wrangler Technical Forum 13 08-08-2004 06:23 PM
