Turn singal does not turn off when I turn left. - JeepForum.com
post #1 of 32 Old 01-19-2010, 10:34 PM Thread Starter
MWguy101
I have a 95 jeep that I have been rebuilding. I am having an issue with my turn signal. When I turn left the turn signal does not click off. But when I turn right it does. Is this a hard fix? Do I have to rip into the steering column?
MWguy101 is offline
post #2 of 32 Old 01-20-2010, 02:04 AM
Gobi_Gred
1987 YJ Wrangler
WELCOME.
I cant help you, but I can tell you that your lucky it sticks down.
I have to hold mine down
At least I'm good for a bump till the morning crew gets here
Gobi_Gred is offline
post #3 of 32 Old 01-20-2010, 02:20 AM
timatoe
timatoe's Avatar
I'll bet that you've recently installed a lift and your steering wheel does not set straight. Park somewhere where the tires are straight, then get up under there loosen the ends on the drag link and twist it until the steering wheel is straight. Repeat as necessary.
timatoe is offline
post #4 of 32 Old 01-20-2010, 06:04 AM
tippmann243
sounds the the blinker cam cancellation spring broke. i have replaced many of those with the chevy/jeep style column
89 blazer, L31/t56 28mpg.
blazer video,
1990 jeep, 4.2, 5speed.
tippmann243 is offline
post #5 of 32 Old 01-20-2010, 12:07 PM
airdevil85
mine doest the same thing with the left turn sig... the right one turns off sometimes... I just got used to turning it back off lol
airdevil85 is offline
post #6 of 32 Old 01-20-2010, 01:59 PM
rboppre
I just fixed this in my 94 yj. I installed and new turn signnal multifunction switch. The spring was broken that cancels the turn signal. It just got to be annoying so I had to spend the $25 and fix it. If you have any question feel free to ask while I have it fresh in my head. Good luck
rboppre is offline
post #7 of 32 Old 01-20-2010, 05:02 PM
92 Green YJ
92 Green YJ's Avatar
yeah my YJ has done that ever since I got it. I just got in the habit of turning it back off manually. though I admit I do forget it sometimes and end up looking like an old lady driving around with my blinker on
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #8 of 32 Old 01-21-2010, 12:28 PM
airdevil85
lol me too... drove all of 15 miles to work then realized I was still turning left off my road lol
post #9 of 32 Old 01-21-2010, 01:19 PM
H3RTCH
Live Free or Die.
H3RTCH's Avatar
I've done that once where my father was following me. Needless to say pokes were poked That was when it still worked too! Darn merges.
Brandon
2004 Jeep WJ Grand Cherokee Overland - My DD
1988 Jeep MJ Comanche 4.0L - Dad's
1999 Jeep WJ Grand Cherokee Limited 4.0L - Mom's
H3RTCH is offline
post #10 of 32 Old 02-12-2010, 08:52 AM Thread Starter
MWguy101
How hard is it to fix? Where did you get the parts at?
MWguy101 is offline
post #11 of 32 Old 02-12-2010, 09:39 AM
humbert810
My left one doesn't turn off either. I now just have the habit of clicking it back off. Real fun when I go to drive a car where it works and I keep trying to turn it off but it's already off.
RED 1995 Wrangler YJ DD
Front and Rear custom bumpers
4" RC Susp. Lift
33x12.50x15 Firestone Destination MT's
This forum requires that you wait 60 seconds between searches. Please try again in 1 seconds.
humbert810 is offline
post #12 of 32 Old 02-12-2010, 09:58 AM
erockz
If alignment is correct(steering wheel is straight when driving straight ) see above quote for repair.
erockz is offline
post #13 of 32 Old 02-12-2010, 10:36 AM
rboppre
turn signal cancelation
I got the parts at auto zone. The fix wasn't that hard.
rboppre is offline
post #14 of 32 Old 02-12-2010, 12:01 PM
monkeyhouse
so what if the steering wheel is not straight when driving straight? Neither of my signals turn off by themselves, I have seen previous posts about replacing the springs, so I will definitely do that, but I know for a fact that my steering wheel is way off.
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
post #15 of 32 Old 02-12-2010, 12:03 PM
Mobile_Homie
Desert Rat
Mobile_Homie's Avatar
Must be a Jeep Thing
Mine does too. I have the new canceling cam in the garage, just haven't got around to pulling the wheel.
Mark
Smoke em if you got em!
Mobile_Homie is offline
Turn signals stop working when I turn my lights on? Toner12 YJ Wrangler Technical Forum 1 08-10-2008 05:54 PM
Steering Problem Help! left turn fine.... start to turn right & there is a delay. opie2l TJ Wrangler Technical Forum 2 06-23-2008 01:00 PM
turn left....squeak...turn right...nothing 95YJRookie YJ Wrangler Technical Forum 7 10-05-2006 03:07 PM
Turn signal to fast, brake/turn fuses blowing and a gas gauge with an identity chrisi pyro9862 YJ Wrangler Technical Forum 3 06-29-2005 01:35 PM
Turn Singal Madness rick95 YJ Wrangler Technical Forum 4 02-10-2005 02:41 PM
