Turn Signals stop flashing when Headlights turned on...Please Help!! - JeepForum.com
post #1 of 19 Old 07-20-2014, 02:49 AM Thread Starter
TmcT
Hey ALL,
I'm new to this forum, looking for some help ASAP.
I've got to send my Jeep for an out of province inspection in two days and i'm having issues with the front turn signals. They stop working (stay on solid) when I turn the headlights on. I've replaced the flasher, bulbs, and tested a couple connections by the signal light that was first giving me issues (front right). Now both front lights don't flash. Both tail lights and front left marker light flash no problem. Front right marker light doesn't come on at all even with new bulb in place. I'm in a serious time crunch and spent a solid 4 hours pulling apart switches and connectors, wires, etc today with still no results. Any ideas? or perhaps a better method to troubleshoot the issue? I'm new to vehicle wiring as well. I bought a test light and pulled out my Voltmeter to give this a solid effort.
TmcT is offline
post #2 of 19 Old 07-20-2014, 02:57 AM Thread Starter
TmcT
I'm leaning towards it being a ground fault issue maybe, but I'm not sure the best method for troubleshooting that? Especially since there seems to be several ground wires sharing the same location to the body.
I can say the front right turn signal was giving me problems first (not turning on at all, then going on if I tap on the cover but staying on solid and bright), then when I replaced the bulbs in both front signal lights they both stay on now steady without flashing once I turn the headlights on, but they both flash normal with the head lights out..... that's why I think ground issues... I heard that the ground for the lights change when the headlights are on/off.
Also the front right marker light has not worked in years but never looked into why (probably related) i changed the bulb and still nothing, i think the connector is faulty so I cut it off to replace hopefully I can find one at a local parts store *(any way to by-pass this if i run out of time?)...
Thanks to anyone who can help me sooooooon.
TmcT is offline
post #3 of 19 Old 07-20-2014, 03:10 AM Thread Starter
TmcT
My out of province inspection is Tuesday AM so I'm on a serious mission to get this solved.
TmcT is offline
post #4 of 19 Old 07-20-2014, 03:52 AM
Mike Romain
The front fixtures need to be grounded with the special shoulder screws used. These screws clamp the fixtures to the grill.
The side markers wire in using the running light wire for power and the signal light wire for ground. This makes them flash with the signals when the headlights are off and alternate flash when the lights are on. The socket is a common one that Canadian tire or Napa has. GM vehicles Aldo use these sockets.
Mike
Mike Romain is offline
post #5 of 19 Old 07-20-2014, 12:55 PM Thread Starter
TmcT
Thanks Mike! I'll try remounting the ground wire to the body. Just to clarify, are the "special shoulder screws" just the ones with a washer that has jagged sides? Can I buy these at Can tire perhaps? If so, what would they call them?
Also to clarify, this is the ground location to the right of the headlight close to the radiator mount... is there any other ground locations I should be remounting?
Secondly:
If my voltmeter with the red terminal on the battery positive and the black on this ground point, should there be any reading? No right? Would that be the best test of a good ground to this location?
TmcT is offline
post #6 of 19 Old 07-20-2014, 01:12 PM Thread Starter
TmcT
ANY IDEA WHY THIS IS WIRED TO THE DEFECTIVE RIGHT MARKER LIGHT?
*Also as a total automotive electronic newbie what is it???* looks like a fuse to me?
When checking the wiring and ground to the aforementioned right marker light I found this spliced into the power wire (blue/red) coming from the turn signal directly.
It was soldered into a split in the wiring and goes to nowhere but a loose ground by the jack mount (found the whole black square part sitting in the empty jack mount)
So there were 4 wires all crazy taped together into a bundle. Red one from the turn signal had 12v power, the black was to the ground on the body. Two red wires just taped all up going nowhere, one with a dirty 30A fuse (was in the white part by my thumb) as part of it's run.
-Should I put this back in place when I reinstall the marker light connector?? That's my real concern..
-Could this be someone's wiring solution to adding fog lights at some point in time? Just left sitting around?
TmcT is offline
post #7 of 19 Old 07-20-2014, 01:22 PM Thread Starter
TmcT
I don't think my haynes diagram shows this as being a part of the wiring, I don't know for sure... NEWBIE!
TmcT is offline
post #8 of 19 Old 07-20-2014, 01:24 PM Thread Starter
TmcT
I must admit this is the first time i've ever tried to read one of these things....
so I could be blind or just ignorant. But i'm learning
TmcT is offline
post #9 of 19 Old 07-20-2014, 01:45 PM Thread Starter
TmcT
one more stupid question:
-when it says left headlight, right headlight etc. in the diagram... is that looking at the vehicle from the front using my left and right? or from the back looking forward? I couldn't find any solid landmarks in the wiring diagram to give me those bearings...
I'm literally brand new to wiring as of yesterday
TmcT is offline
post #10 of 19 Old 07-20-2014, 02:50 PM
littleredjeep
If I am not mistaken all you stuff will be from sitting in the drivers seats. Including tie rod ends and ball joints too for future reference.
88 YJ 4.2, 5-speed, 4"RC lift, 5/8 booms, herced tub, and cavi seats
My build thread
_____
/| ,[___],
|--L --[]lllll[]-
()_) ()_)-o-)_)
littleredjeep is offline
post #11 of 19 Old 07-20-2014, 03:16 PM Thread Starter
TmcT
I'm at the Canadian Tire (automotive) right now and they treated me like I was a moron for asking for "special shoulder screws"
Any idea what else they could be called? Or a description?
I explained to their techs what I'm using them for and they had no clue..
TmcT is offline
post #12 of 19 Old 07-20-2014, 04:33 PM Thread Starter
TmcT
Any way I can just use a screw and washer or bolt for the ground to body?
TmcT is offline
post #13 of 19 Old 07-20-2014, 04:34 PM Thread Starter
TmcT
Thanks littleredjeep!
TmcT is offline
post #14 of 19 Old 07-20-2014, 04:48 PM Thread Starter
TmcT
Looks to me like the old screws being used for mounting are just silver self tapping screws
TmcT is offline
post #15 of 19 Old 07-20-2014, 05:56 PM
littleredjeep
It really doesn't matter that much what you use as long as it stays tight and has a good clean surface to make a solid ground. If you don't have a solid ground some crazy stuff can happen with electrical stuff.
My build thread
_____
/| ,[___],
|--L --[]lllll[]-
()_) ()_)-o-)_)
