Turn signals/lights acting up - JeepForum.com
post #1 of 8 Old 01-15-2010, 02:10 PM Thread Starter
VACJ5
Okay guys...
1- when I turn on my lights my drivers fender signal and my passenger grill turn signal dont come on... I tap the fender and the grille and they come right on no problems. I am thinking that this is a bad ground?
2- When I hit the brakes my driver's side rear light cuts out completely. (I checked the bulb, it looks fine)
3- When I try to use the driver's turn signal... nothing... when I use the passenger signal... it works but is real slow to blink...
Any ideas?!?!?!?!
79 CJ5 Silver Anniversary Edition... revived & sold *sniff
91 YJ 4.0 L, with some stuff bolted to it...
91 2 door Cherocar... in progress
Custom CNC cut Jeep parts & more
VACJ5 is offline
post #2 of 8 Old 01-15-2010, 04:05 PM
Mark05059
you have some bad grounds... clean all the grounds on the lights the rear ones are the mounting screws)
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 8 Old 01-15-2010, 04:16 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
I agree!
The giveaway is in your #2 statement, when trying to use the brake light circuit it causes a previously working function to cease. This is the "signature" of a faulty ground. The higher amp circuit is "looking" for a place to get to ground. It overpowers & "back-feeds" through a lower amp circuit.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #4 of 8 Old 02-24-2010, 05:52 AM Thread Starter
VACJ5
Now both my turn signals work when the lights are off. As soon as I but my lights on the left will freeze up and not blink, but the right works regardless. I still have the issue with the drivers side brake and reverse light.
I had my utility trailer behind my jeep... plugged it in and the left signal seemed to work. I am going to assume that it was because my trailer's wiring harness has a good ground. Where are the rear grounds on the jeep? Could I tap into the ground wire (which one?) and just make a new ground somewhere?
VACJ5 is offline
post #5 of 8 Old 02-24-2010, 06:15 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
The rear light's ground is the bolts holding it to the tub. Take em out and clean everything up well. Put them back in snug and see what happens.
Check the rear bulbs by swapping left to right and see if it works.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #6 of 8 Old 02-24-2010, 06:40 AM Thread Starter
VACJ5
Tried that, no glory... I will take the lights off and wire wheel the blots and see what happens. Thanks man.
VACJ5 is offline
post #7 of 8 Old 02-24-2010, 03:52 PM Thread Starter
VACJ5
Ayup... I took the mounting screws to the wire wheel on the bench grinder and I had to take a small wire brush to the metal plate in the back of my tail light... works fine now! Thanks fellas!
VACJ5 is offline
post #8 of 8 Old 02-24-2010, 03:59 PM
ZillaKing
WOW!!! I have the same problem...Jeep Forum.com is thee BEST!!!
ZillaKing is offline
Turn signals are acting strange.... hardijr YJ Wrangler Technical Forum 6 03-17-2009 07:44 AM
rear turn signals acting crazy drumkite2 TJ Wrangler Technical Forum 10 01-08-2009 04:59 PM
Turn signals stop working when I turn my lights on? Toner12 YJ Wrangler Technical Forum 1 08-10-2008 05:54 PM
brake lights, ok; tail lights/side markers/turn signals not.... help? LoneJeeper TJ Wrangler Technical Forum 2 09-12-2005 08:18 PM
No turn signals or Brake lights Patton TJ Wrangler Technical Forum 1 09-10-2002 06:45 AM
