turn signals and brake lights - JeepForum.com
post #1 of 5 Old 10-15-2013, 01:48 PM Thread Starter
JMcGovern11
Hey everyone. I was having a problem where my fog lights would stay on and I determined it was the combination switch. So I swapped out the switch and now my turn signals and brake lights don't work. Only my 3rd brake light works. It doesn't even light up in the dash so I know it's not just a bulb. I think I might have a wiring problem now. Any suggestions?
JMcGovern11 is offline
post #2 of 5 Old 10-15-2013, 03:30 PM
bigbossd1030
make sure all the pins in the wide pigtail that attaches to the bottom of the column are all contacting. My brake lights didn't work because of this.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #3 of 5 Old 10-15-2013, 09:53 PM Thread Starter
JMcGovern11
Ok thank you! I'll check it out!
post #4 of 5 Old 10-16-2013, 07:31 AM
bigbossd1030
If you have a small screwdriver (precision) you can bend the tabs on the inside out slightly, that way they contact nicely. Also a small amount of dielectric grease will help. Just a dab on the end of a tooth pick.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #5 of 5 Old 10-30-2013, 01:35 PM Thread Starter
JMcGovern11
Thank You for the help! It ended up being a fuse that we missed the first time. The spot was so tiny that it was barley noticeable. I am just glad I can drive it again
