turn signal part question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > turn signal part question
Father's Day & Moving Day Sale!Engo winch sale-- Best deal you will find. and FREE SHIPPIRough Country Lift Kits and Parts!
Unread 05-14-2011, 08:15 PM   #1
mannyj
i have looked and looked and looked and now the wifes gettin pissy. my lever isnt broke and its a new switch there is a little metal part that connects the lever to the switch and thats what broke. can i snag one off of a chevy at the junk yard as these are a gm column or would that not work?
any help would be great
mannyj is offline   Reply With Quote
Unread 05-14-2011, 09:14 PM   #2
sbsg2005
Got a pick of the part there are several little metal parts inside a column?
This is my Jeep. There are many like it, but this one is mine.
My Jeep is my best friend. It is my life. I must master it as I must master my life.
sbsg2005 is offline   Reply With Quote
Unread 05-14-2011, 11:40 PM   #3
mannyj
its the accuator or thats what they call it in the haynes manual. its the piece that screws onto the turn signal switch and is connected to the turn signal lever. someone has welded it pryor to me owning the jeep and they did a "great" job if i may add. im gonna go get one off of a chevy tomorrow and see what i get i may even grab a few others like ford and dodge to see what will work.
Unread 05-15-2011, 07:01 AM   #4
dodger889
Older gm should work. Ours are the over run stock units.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline   Reply With Quote
Unread 05-15-2011, 09:55 AM   #5
mannyj
thats what i thought bout to go get it let lyou know what i come up with cuz in nebraska we dont have a bone yard for just jeeps we got em full of everything but jeeps
Unread 05-17-2011, 11:35 AM   #6
mannyj
got it came out of an early 80's blazer thanks for the help guys
Unread 05-17-2011, 01:21 PM   #7
Buddha
Manny - Someone else on here shared this with me. I thought it might come in handy for you.
http://www.jeep4x4center.com/jeep-se...uals/index.htm
[COLOR="Yellow"]I have read hundreds, if not thousands, of threads on here and it's amazing the percentage of problems that wind up being caused by something the owner has accidentally done to the Jeep while working on it.
Moral to the story: If you moved it, unscrewed it, unbolted it, hammered on it, wiped it off, re-wired or replaced it - Check there first![/COLOR]
Buddha is offline   Reply With Quote
Unread 05-17-2011, 01:41 PM   #8
bigbossd1030
bigbossd1030's Avatar
I know you have it but Xj's and Comanches have the same ones too.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline   Reply With Quote
lever , switch , turn signal
