Turn signal issue. - JeepForum.com
post #1 of 2 Old 09-11-2011, 09:24 PM Thread Starter
SpikesHD
1987 YJ Wrangler
Turn signal issue.
I rescued my Heep from a PO who hacked the heck out of the wiring. I had to remove most of the under hood wiring just to get the engine to start reliably.
When I turn the ignition key to 'ACC' the whole dash lights up, seatbelt buzzer and all. I found out why, there is a yellow wire in the harness under the hood connected to a white wire that goes directly back to the fuse block. I haven't found out what he screwed up to have to do that yet.
My issue:
My headlights and marker lights work fine.
My brake lights and turn signals work fine.
When my headlights are off and I hit the brakes, my LEFT front turn signal and front fender marker light come on with the brake lights. Turn signals work fine.
When my headlights are ON my Right turn signals don't work. Just a solid light.
It's puzzling me!
Trailer wiring seems to work fine with headlights off, haven't tried with lights on.
Any ideas?
Si vis pacem, para bellum.
SpikesHD is offline
post #2 of 2 Old 09-12-2011, 03:14 AM
Mark05059
start by cleaning the grounds at the tail lights.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
turn signal issue... Djsthe1 YJ Wrangler Technical Forum 8 11-22-2010 12:09 PM
Turn signal issue DRE. TJ Wrangler Technical Forum 4 11-17-2010 08:32 PM
Turn Signal Issue - Help? Rproject YJ Wrangler Technical Forum 17 12-21-2008 11:47 AM
Turn Signal Issue #2 GreyfoxVt YJ Wrangler Technical Forum 2 05-15-2008 02:57 PM
turn signal issue default_user JK Wrangler Technical Forum 8 08-19-2007 09:30 AM
