Turn signal doesn't shut itself off after turn. - JeepForum.com
post #1 of 18 Old 11-19-2010, 11:24 AM Thread Starter
scifone
Learns the hard way
scifone's Avatar
My left turn signal doesn't shut itself off after I make a left turn. But it does after turning right. What would cause this problem? I hope I don't have to tear my steering column apart to fix this. I have tried searching but haven't been able to come up with anything. So what say you JeepForum?
scifone is offline
post #2 of 18 Old 11-19-2010, 11:30 AM
xWhite420wIDOWx
1967 CJ5
I had the same problem with my old truck... It's the turn signal switch cause they wear out over time...
xWhite420wIDOWx is offline
post #3 of 18 Old 11-19-2010, 11:32 AM
kelti819
^^^what he said^^^
kelti819 is offline
post #4 of 18 Old 11-19-2010, 11:46 AM
bhartwell59
1987 YJ Wrangler
or do what most drivers in front of me do... don't use your turn signal.
sorry had to say it.
4.2 '87 yj, 300,000+ miles, mopar mpi, 33" bfg mud KM2, skyjacker 4", 3.73 gears, arb lockers-f and r., tom wood's 2.07 sye conversion, tom wood's hd driveshaft, magnaflow cat/custom exhaust, 4wd rear bumper/swing-out tire carrier
bhartwell59 is offline
post #5 of 18 Old 11-19-2010, 12:24 PM Thread Starter
scifone
Learns the hard way
scifone's Avatar
How hard is it to replace that switch?
scifone is offline
post #6 of 18 Old 11-19-2010, 12:51 PM
bhartwell59
1987 YJ Wrangler
i think you need to get to the canceling cam
Tilt Column Fix - Dale's Jeep Junk
post #7 of 18 Old 11-19-2010, 01:21 PM
Destr0
I agree, it is not the switch, it is the turn signal cancelling cam. Kind of a pain to replace, but at least the part is cheap! :-)
I have one sitting in my parts bin. Been there for a few months now because I needed one and it was like $4 and I added it to another internet parts order. Then I found out what it requires to install... I am looking for a tilt column so I have been putting off installing this one. :-)
Destr0 is offline
post #8 of 18 Old 11-19-2010, 01:27 PM
sherwoodiv
Is your steering wheel straight?
1991 YJ 4.0 MT
2001 TJ 4.0 MT
sherwoodiv is offline
post #9 of 18 Old 11-19-2010, 02:05 PM Thread Starter
scifone
Learns the hard way
scifone's Avatar
It sounds like the canceling cam is my ticket.
My steering wheel isn't straight but that doesn't matter because it wont shut off no matter how far I turn the wheel. I sat in a parking spot and tried to get the signal to click off and I got all the way to the steering stop and it wouldn't shut off. Regardless it just stopped working the other night.
scifone is offline
post #10 of 18 Old 11-19-2010, 02:08 PM
sherwoodiv
Well then its probably the cam. My steering wheel was about 45 degrees one way and one way my turn signal would almost never cancel. Straightened my steering wheel with the drag link and it went away.
If it just started happening suddenly its probably that canceling cam.
1991 YJ 4.0 MT
2001 TJ 4.0 MT
post #11 of 18 Old 11-19-2010, 02:17 PM
SpideYJeep
or you lost one of the two springs on the switch which the canceling cam uses to cancel.... Hmmm...just like mine LOL. Now, my left hand acts as the canceling cam for left turns....
Wrenching isn't the problem, it's the brains attached to the hands...unfortunately, I'm lacking some of the former so that's why I'm asking you guys!!
Originally Posted by YJake View Post
My YJ is so excited it's leaking oil!
SpideYJeep is offline
post #12 of 18 Old 11-19-2010, 02:25 PM Thread Starter
scifone
Learns the hard way
scifone's Avatar
I keep finding myself not realizing my turn signal is on like some of the old people around here.
On a side note, anyone know the model number of the flasher we can use that's louder than the stock one? I can't hear mine now for the life of me.
scifone is offline
post #13 of 18 Old 11-19-2010, 05:00 PM
bazz
mine does the exact same thing, I just turn it off manually..
you can build it on the cheap... but build it right, short cuts will kill you and a busload of church kids
bazz is offline
post #14 of 18 Old 11-19-2010, 05:29 PM
Xtremjeep
Mine was same way, the spring worked it's way out but was not broken. Popped it back in and works great.
Build Thread:
1980 CJ-7 Mall crawler (RIP 2010)
1983 CJ-8 Scrambler Full resto in progress
1988 YJ Fully Built but never Done
Xtremjeep is offline
post #15 of 18 Old 11-19-2010, 05:30 PM Thread Starter
scifone
Learns the hard way
scifone's Avatar
How did you do that??
scifone is offline
Broken turn signal lever, Need to turn OFF hi-beams Tulsachokehold YJ Wrangler Technical Forum 16 12-10-2014 12:39 AM
Horn wont shut off after new turn signal switch johnoutdoors YJ Wrangler Technical Forum 13 01-29-2008 08:16 AM
Help, Turn signal going solid when headlights turn on??? Nickb1907 TJ Wrangler Technical Forum 3 12-24-2007 06:26 PM
turn signal does not shut off after turning rsalerno TJ Wrangler Technical Forum 3 10-09-2007 01:49 AM
Turn signal to fast, brake/turn fuses blowing and a gas gauge with an identity chrisi pyro9862 YJ Wrangler Technical Forum 3 06-29-2005 01:35 PM
