Turn signal and brake lights not working - JeepForum.com
post #1 of 15 Old 10-17-2015, 01:07 PM Thread Starter
TastemyToast
Title says it all, bulbs are fine, where do I go from here, really new to this.
TastemyToast is offline
post #2 of 15 Old 10-17-2015, 01:12 PM Thread Starter
TastemyToast
Hazard and running lights work.
post #3 of 15 Old 10-17-2015, 03:54 PM Thread Starter
TastemyToast
It's a 92 4.0, all the fuses under the dash are good as far as I can tell.
post #4 of 15 Old 10-17-2015, 04:09 PM
dancytron
Well, start out by cleaning things up. Take all the bulbs out of their sockets, clean stuff up, put some dielectric gel on the base of the bulbs and put them back together. The ground for the brake lights/tail lights is the mounting bolts. Take them off, clean the contacts up until their are nice and shiny, and put them back together.
Switch the flasher for the hazards and the blinkers (the two round things at the fuse box) to see if that fixes the blinkers.
I know you say the bulbs are good, but if that doesn't work, I'd think the next thing to check is if the bulbs are really good.
After that, report back.
dancytron is offline
post #5 of 15 Old 10-17-2015, 07:04 PM
Drednot
Fronts and rears? Just rears?
If the hazards and taillights work, its up front somewhere unless there is some trouble with a trailer wiring plug. From the body harness connector back, its the same wires for hazards and brake and turn. The magic happens in the turn signal switch
91 YJ Sahara, 4.0L, AX-15/NP231, D30/D35@3.07
12 Cherokee 4x4,3.7L,42RLE/MP1522, D30M/8.25@3.73
Emission test=YES
"Non Vi Sed, Arte"
Drednot is offline
post #6 of 15 Old 10-17-2015, 07:37 PM Thread Starter
TastemyToast
Fronts and rears aren't working. I'm at work so I'll have to check it in the morning. Those wiring diagrams are really helpful.
post #7 of 15 Old 10-18-2015, 02:34 PM Thread Starter
TastemyToast
So, replaced the fuses and relays, still no lights. Got a new turn signal switch from autozone, gonna put that in tomorrow. All the wires are testing good, so hoping that is going to fix the problem, I'll update tomorrow.
post #8 of 15 Old 10-19-2015, 06:21 AM
Que89YJ
Hazards and turn signal are both not working they are on separate fuse feeds. If they both stop working it is usually the switch.
Que89YJ is offline
post #9 of 15 Old 10-20-2015, 11:22 AM Thread Starter
TastemyToast
Replaced the turn signal switch, now the brake lights work, but signals don't. Any ideas?
post #10 of 15 Old 10-20-2015, 12:28 PM
Drednot
backup lights work?
Emission test=YES
"Non Vi Sed, Arte"
Drednot is offline
post #11 of 15 Old 10-20-2015, 12:44 PM
Que89YJ
Hazards?
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #12 of 15 Old 10-20-2015, 12:51 PM Thread Starter
TastemyToast
Backups and hazards both work. Just no turn signals.
post #13 of 15 Old 10-20-2015, 01:24 PM
Drednot
check for battery voltage at/through fuse #4
check for battery voltage at flasher socket terminal "A"
Check for battery voltage at hazard/turn switch connector terminal "L"
Emission test=YES
"Non Vi Sed, Arte"
Drednot is offline
post #14 of 15 Old 10-20-2015, 02:22 PM Thread Starter
TastemyToast
Update, I forgot to put the relay and fuses back in. Turn signals are fine now, everything is working 100%.
post #15 of 15 Old 10-20-2015, 09:12 PM
Drednot
LOL
Emission test=YES
"Non Vi Sed, Arte"
Drednot is offline
