Turn Signal - JeepForum.com
post #1 of 4 Old 02-12-2014, 10:44 PM Thread Starter
Curiousjosh
Turn Signal
I just recently bought a 1995 yj. I noticed when driving it for the first time that whenever I turned left my turn signal would not automatically click off once the wheel came back around. Each time I would have to manually click it off as I would for changing lanes. However when I turn right everything is fine. What part do I need to fix this and what steps should I take to repair it?
Curiousjosh is offline
post #2 of 4 Old 02-12-2014, 10:52 PM
Why J?
Why J?'s Avatar
Replace this:
http://www.4wheelparts.com/Lighting-...pn=OAI17232.04
New Project "Pissed Wife"
Phase II 5.3L/4L60e then NV3550
Why J? is offline
post #3 of 4 Old 02-13-2014, 05:50 PM
rubisean
broken return spring( it is on the directional switch) one on the left side and one on the right side. when you take it apart and look you will see one is missing.... there should be two
rubisean is offline
post #4 of 4 Old 02-14-2014, 04:38 AM
90DesertTanYJ
Go to AZ and borrow a steering wheel and a lock plate puller. Once you remove those two pieces and a couple more, you should see what is up. Sean is spot on and you may see the little spring laying in there and can reinstall it. If not, buy a new turn signal switch assembly. The only hard part is snaking the wire harness out then in. I put tape on mine to hold the connector sideways so it fits better.
90DesertTanYJ is offline
