tummy tuck - JeepForum.com
post #1 of 10 Old 07-20-2004, 05:27 PM Thread Starter
livepol16
tummy tuck
has anyone ever done a "tummy tuck"? making the skid plate flush with the frame just want to see what im getting into
livepol16 is offline
post #2 of 10 Old 07-20-2004, 05:45 PM
TellyDSP
Poland and PPV!!!!
It's possible, however, you're going to have to do some tub cutting and play with new driveline angles, depends on your skill level. I would recommend a prefabbed belly-up skid.
Here's a link to similar modding...PBB Flat Skid
-Craig-
95 Rio Grande
07 Ram 1500
Originally Posted by Jeeples
n00bs bashing n00bs, it's a pitifull thing.
TellyDSP is offline
post #3 of 10 Old 07-20-2004, 09:37 PM Thread Starter
livepol16
i have a sye kit and a tom wood drive shaft i am going to install and i figured while everything was disconnected i would just build a transfer skid plate or buy one if possible. and can you just buy a belly up skid plate for a yj? i can make one but id rather buy one so i dont mess up.. im only 19 and tend to make small mistakes on stuff like that and i have to drive to my relatives house to use there stuff.
post #4 of 10 Old 07-20-2004, 09:39 PM Thread Starter
livepol16
what if you did a 1" body lift would that help ive been talking to some people and they said that it will help with the shifter and with the angle
post #5 of 10 Old 07-20-2004, 09:44 PM
tube yj
tube yj's Avatar
1949 CJ3A
i run one on my yj and did not have to cut any of the floor out. I just used a sheet of 3/8 inch flat steel and traced out the shape of the stock skid plate. I resused the transmition mount off of the stock skid. I used counter sunk bolts to smooth it out
here is a pic
tube yj is offline
post #6 of 10 Old 07-20-2004, 10:24 PM
ErikJordan
Pimp Hand
ErikJordan's Avatar
i used the nth degree tummy tucker. it is a nice piece of steel.
not too cheap, but fits very well, and is a great design.
a motor mount lift, and sye are manditory. it is a very nice mod.
___________________________________________
What is all of this talk of Savvily designed products?
ErikJordan is offline
post #7 of 10 Old 07-21-2004, 06:17 AM
GrimJeeper91
GrimJeeper91's Avatar
I went with the belly up kit. It's a complete and quality set up. It comes with the mounter mount spacers and I also put on a 1" body lift to maintain clearances and avoid having to cut into the body tub (more room for larger tires too). Big, beefy and flat skid.
'91 YJ 4.O, Auto, Rr. D60 w/ 35 Spline Alloy USA Axles & Detriot Locker, Fr. D30 True-Trac, 4.56's, 4.5" Deaver Springs, Bilstein 5100's, 1" BL, Rubi Flares, 35x12.50 MT/R's on MT classic II's, Detroit Locker, Vanco Big Brakes, Booster & Master, Warn 9000XDI, York OBA, AA SYE & TW's DS's, Teraflex Belly Up, Rocker Guards...
GrimJeeper91 is offline
post #8 of 10 Old 07-21-2004, 08:08 AM Thread Starter
livepol16
hey nailer where did you buy the nth degree tummy tucker?
post #9 of 10 Old 07-21-2004, 09:25 AM
ErikJordan
Pimp Hand
ErikJordan's Avatar
http://www.nthdegreemobility.com/
here is the link
post #10 of 10 Old 07-21-2004, 10:10 AM Thread Starter
livepol16
thanks man
Tummy Tuck on a YJ? KRenegade YJ Wrangler Technical Forum 22 12-31-2011 01:35 AM
Tummy Tuck AustinCJer TJ Wrangler Technical Forum 11 09-11-2009 04:53 AM
AEV Tummy Tuck outlawjosywales TJ Wrangler Technical Forum 6 03-20-2009 01:31 PM
Tummy Tuck ?? tdog522 TJ Wrangler Technical Forum 5 10-29-2008 06:29 PM
tummy tuck, without tuck chadsmeltzer TJ Wrangler Technical Forum 26 01-28-2008 05:31 AM
