Tuffy console jammed!! help! :brickwall - Page 2 - JeepForum.com
post #16 of 46 Old 08-16-2011, 04:13 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Grab the lock with a set of your best pliers and twist back and forth to see if the center section will come loose.
Luck Favours The Prepared
Anticanman is offline
post #17 of 46 Old 08-16-2011, 04:17 PM
sbsg2005
Can you get the lid up high enough to get something thin in there like a stir stick for paint. If so try to use the stir stick to get it unjammed. Use a hammer and a screw driver to try to chisel the hinge off.
sbsg2005 is offline
post #18 of 46 Old 08-16-2011, 04:23 PM Thread Starter
ibacavergrl
its not that something is jammed against the lock... its inside the lock ... i shoved my acu top into the console... and shut the lid which caused my top to get jammed within the lock itself
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
"93 Jeep YJ"
ibacavergrl is offline
post #19 of 46 Old 08-16-2011, 04:35 PM
bigbossd1030
Get a pic of the hinge, is it spot wedwd on, if so drill the spot welds out and there ya go. If its the locking mech that is jammed I would drill it out with a very large bit and get a new lock
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #20 of 46 Old 08-16-2011, 04:40 PM Thread Starter
ibacavergrl
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
"93 Jeep YJ"
post #21 of 46 Old 08-16-2011, 04:41 PM Thread Starter
ibacavergrl
the hinge is welded on inside the console... FML
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
"93 Jeep YJ"
post #22 of 46 Old 08-16-2011, 05:03 PM
sbsg2005
If you have a drill take bit that is a little bit bigger than them two spot welds and drill them out. Then use a hammer and a screw driver and tap and the back lip of the lid and the back will pop right up. For the repair a couple 1/4 20 bolt and nuts, rivets, or have them welded back together.
sbsg2005 is offline
post #23 of 46 Old 08-16-2011, 05:44 PM Thread Starter
ibacavergrl
So... tried to drill out the welds... no go.... so i did the next logical thing...
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
"93 Jeep YJ"
post #24 of 46 Old 08-16-2011, 06:01 PM
sbsg2005
Well that will take a little bit more than a couple nuts and bolt to fix. Instead of buying another tuffy might I suggest a ammo can console. Should be pretty easy to find one.
sbsg2005 is offline
post #25 of 46 Old 08-16-2011, 06:05 PM Thread Starter
ibacavergrl
need something alot more secure than an ammo can.... i never ride w doors or a top
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
"93 Jeep YJ"
post #26 of 46 Old 08-16-2011, 06:23 PM
timatoe
timatoe's Avatar
You've apparently not seen some of the ammo can consoles guys here have come up with.
timatoe is offline
post #27 of 46 Old 08-16-2011, 06:24 PM Thread Starter
ibacavergrl
im looking around now.... trying to find them... i have access to ammo cans for free..
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
"93 Jeep YJ"
post #28 of 46 Old 08-16-2011, 06:30 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Looks like you dug out the ol can opener out of the tool box.
post #29 of 46 Old 08-16-2011, 06:36 PM
jvallery
Someone should send this thread to Tuffy. Quite a testament to their products! I've got the Tuffy center console, overhead console, and glove box. I've got several spare keys so hopefully I never run into this situation! :-)
jvallery is offline
post #30 of 46 Old 08-16-2011, 06:39 PM Thread Starter
ibacavergrl
u better hope not... took me and a buddy 4 freaking hours to open it... and it WASN'T EVEN LOCKED
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
"93 Jeep YJ"
tuffy console vs tuffy glove box kgb TJ Wrangler Technical Forum 16 03-22-2009 05:37 PM
Tuffy Console Insert in 2004 console? canuck_bob TJ Wrangler Technical Forum 8 07-10-2008 12:03 PM
Anyone put a tuffy console insert into an 01+ Sub console? XabuJr TJ Wrangler Technical Forum 1 07-06-2007 09:40 PM
Tuffy console for an '04? JeepsterWC04 TJ Wrangler Technical Forum 9 08-19-2004 10:18 AM
Will a Tuffy console insert work in a sub console? Stricken TJ Wrangler Technical Forum 2 07-07-2004 09:40 AM
