#1 | ||
tube fender build
#2 |
![]() Pics?
2008 Dodge Ram Quad Cab 4X4-Leveled, tinted and slightly larger tires 92 YJ- 4.0, Auto, 231TC, SYE, TW Driveshaft, 35's, Pro Comp coil coversion, Header/full exhaust, rock sliders, MORE motor mounts, and... |
#3 |
Bending joints
That's cool. Are we gonna see pictures or details?
1990 YJ = The Toy/ My Daily Driver 1996 XJ= Wifes Daily Driver |
#4 |
sorry im pulling them off my droid
#5 |
most of the bent parts
#6 |
the cheap tube bender that does work
#7 |
rear fender bent
#8 |
finished bent parts and a messy workstation
#9 |
the back will consist of side panels bolting up all sheet metal is being made of 11ga steel and the tube is 1 1/4" .120 wall its not dom tubing
#10 |
the damage
#11 |
so in order to repair the damage to the flares and the bumper i decided rather than buying just some plastic fender flares i was going to make metal flat fenders for the front and rear tube fenders with side panels for increased protection i also will be making a bumper and used 11ga for rocker guards they dont go below to the body mounts though and i made a stinger so far im into the project 175 bucks with the rear panels being cut on the plasma cam bye bye birthday money i was actually gonna use the money to change my gears in the front so i could have 4wd again but no such luck
#12 |
Can you spare a quarter?
How do you keep that bender from making flat spots and kinks in the tube?
No longer Jeepless.... |
#13 |
Mall crawler
I used that same HF bender, used the same pipe(1x.120 HREW), and welded it all up with my hobart wire welder.
The rear.. The front is a work in progress. ![]() ![]() ![]() ![]() ![]() ![]() |
#14 |
Bending joints
Those look good
#15 |
you make sure you have the seam pointed down go slow and move the bend if its a big one it did kink my stinger due to the angle
| Thread Tools | |
| Thread | Thread Starter | Jeep Forums | Replies | Last Post |
| Tube Fender Build | telkinsjr | TJ Technical Forum | 2 | 11-01-2009 01:31 PM |
| Tube fender/flat fender options thread... | BlueJeepRME | TJ Technical Forum | 10 | 04-15-2009 01:00 AM |
| Gen-Right Hi-Fender kit (tube fender & high line combo) | john NC | TJ Technical Forum | 44 | 02-19-2009 10:24 AM |
| Tube fender install. Relocate inner fender items where? | Killedbybob | TJ Technical Forum | 3 | 07-29-2008 03:50 PM |
| Tube fender build | alex71 | TJ Technical Forum | 5 | 07-20-2007 08:16 PM |
The time now is 02:56 PM.
Jeep®, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation. JeepForum.com is not in any way associated with Jeep or the Chrysler Corp. |
