Tub Removal - Page 4 - JeepForum.com
post #46 of 52 Old 08-30-2013, 10:22 PM
NHfireLJ
NHfireLJ's Avatar
Originally Posted by Rugby_3 View Post
For everyone that did this how long did it take you to remove the tub? I need to take my fenders off already and my hood needs some attention so I should do the tub as well when it's all apart. How long did it take to put it back on as well? Thanks
Goes pretty quick... 3-4 hours to half a day, off, and then the same on again...
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #47 of 52 Old 11-06-2013, 06:19 PM
kevinmc
I know this thread has gone yet Idle again but I have to ask this. I just purchased the frame from a 90 YJ to put under my my 93 YJ from what I have read overall length of the 93 is different than the 90 and the Roll cage set up is different were there changes to the body mounts to accomodate the different overall length or was that just because of bumper design?
kevinmc is offline
post #48 of 52 Old 11-06-2013, 06:26 PM
NHfireLJ
NHfireLJ's Avatar
Tubs and frames are the same... roll bars were different... so no changes in body mounts...
what engine do you have? what did the doner frame have?
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #49 of 52 Old 11-07-2013, 11:10 PM
kevinmc
Donor frame is from a 90, same engine
Donor frame alos came with steering box, front and rear axles, new front shocks, Leafs are in better shape
Missing is cross member for the transmission although on most frames I have looked at that this has been missing ??? ?
kevinmc is offline
post #50 of 52 Old 11-10-2013, 09:26 AM
NHfireLJ
NHfireLJ's Avatar
Yeah most will save or sell the belly skid...
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #51 of 52 Old 01-05-2015, 04:26 PM
brett12018
I'm doing this right now but there is a rubber grommet preventing me from pulling the ebreak cable out, did you remove the rubber piece as well and if so how did you remove it?
brett12018 is offline
post #52 of 52 Old 01-05-2015, 04:29 PM
NHfireLJ
NHfireLJ's Avatar
Just yank it... either the cable will pull thru or the grommet will come out with the cable
SOLD
YJOTM FEB 2013
NHfireLJ is offline
A/C Removalů AR-Guy YJ Wrangler Technical Forum 11 11-03-2010 07:55 AM
Air Dam Removal liquidean JK Wrangler Technical Forum 8 09-11-2009 03:12 PM
Oil Pan Removal Help TjBryce TJ Wrangler Technical Forum 3 09-06-2009 04:21 PM
CPS removal seattlejeepster YJ Wrangler Technical Forum 0 03-01-2008 05:04 PM
HT Removal Sidewalkman YJ Wrangler Technical Forum 4 07-12-2003 07:14 PM
