Tub Removal - Page 3 - JeepForum.com
post #31 of 52 Old 11-26-2011, 12:18 PM
craniumboy
My OCD wants me to do this and make sure the frame is good and paint with pot 15 or chassis saver
Keep on Jeepin' on!
craniumboy is offline
post #32 of 52 Old 11-26-2011, 07:24 PM
mbates96
your OCD needs you to get your lift done first!
mbates96 is offline
post #33 of 52 Old 11-28-2011, 09:57 AM
craniumboy
Hopefully by the end of the year!
Keep on Jeepin' on!
post #34 of 52 Old 12-11-2012, 09:15 AM
95Turtle
Probably going to have to do this soon. I didn't see anything about unhooking the heater core hoses... I would assume that has to be done, right? Leftlanetruckin, by unhooking the clutch and brake master cylinders at the pedal and pulling them did you completely avoid bleeding when you put them back together?
Thanks
95Turtle is offline
post #35 of 52 Old 12-11-2012, 01:07 PM
NHfireLJ
NHfireLJ's Avatar
Thanks
Thats what I did for the clutch. I'm in the middel of a frame swap. Would have done the same for the brakes but had to pull all my lines anyhow.
I pulled the heater core hoses at the tub as well.
Leftlanes wriet up made it smooth sailing!
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #36 of 52 Old 12-16-2012, 06:17 PM Thread Starter
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
Sorry, looks like I missed a few replies here.
Looks like all queries have been answered though
Yeah the heater hoses get unhooked from the tub in the engine bay.
The clutch, to be honest, I cant remember too well though, The past few I did got a 4.3/700r4 swap at the same time, so all clutch stuff just got ripped out pretty much.
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #37 of 52 Old 01-13-2013, 11:34 AM
punchie71
i had to take out the rear seat belts as they are botled to the crossmember for the fuel tank.. size 50 torx bit does the trick!
punchie71 is offline
post #38 of 52 Old 03-27-2013, 12:40 PM
whitwt
Thanks for the post. This is my mission this weekend, but with my TJ. I assume they are similar enough. You put a 4.3 in you YJ right? Are you happy with it?
whitwt is offline
post #39 of 52 Old 04-26-2013, 01:04 PM
MadMike03159
Steering shaft
I know this thread has been idle for a while, however it is the best write-up I've found for tub removal. I'm in the process of revamping my 93 YJ with lift, tires, trans, monstaliner paint job and I am going to give the frame a one over while I wait for parts...
Anyways, I'm stuck trying to get the steering column off.
"unbolt the steering joint at the top joint to free the wheel"
I've taken the out the bolt just above the U-joint, I assume thats what the guide is speaking of, and yet the steering wheel will not budge . Any advice?
MadMike03159 is offline
post #40 of 52 Old 04-26-2013, 02:00 PM
MadMike03159
Ended up enlisting the help of my neighbor, a last resort as something always ends up broken. We removed the whole steering assembly from the dash only breaking a wiper connecter... But the steering wheel is free lol.
post #41 of 52 Old 04-26-2013, 08:33 PM
Yarz
Glad you got it.
You also could have removed the bolts on both ends of the shaft, and removed the steering box from the frame to pull the shaft. I don't know how hard the steering assembly is to remove, but sounds harder than this.
The thing is that these steering shafts are supposed to collapse in the center (like the front driveshaft) but are often rusted solid. And the only way to remove them without cutting, as you found out, is pull one end's mounting.
"Build a man a fire, and he'll be warm for a day. Set a man on fire, and he'll be warm for the rest of his life."
1990 White YJ TBI350, SM465, NP231, SOA, RE 1.5" SOA springs, Ford 8.8, D30, 4.10's, JBConversions SYE, XJ shaft, Bilstein 5150s, jb4x4 steering, MORE SS brakelines, 35x12.50 15 MT's, '95 YJ Brake Booster, '78 Grand Marquis MC, ZJ Prop. Valve
Yarz is offline
post #42 of 52 Old 04-27-2013, 07:15 AM
MadMike03159
Wasn't too bad, I'm sure fixing the wire connection will be though. Right now I'm trying to figure out seperating the wiring, everyone mentions remove the large plug from the fire wall beneath the washer tank, but no one mentions the giant wire harness going through the middle upper area of the fire wall. Havn't had much luck with search engines on this, what does everyone usually do with the wire harness? (Can't post picture using my tablet)
post #43 of 52 Old 04-27-2013, 09:07 AM
Que89YJ
I thought that connector was only on the 94, 95. Are you talking about a 12 pin connector?
Que89YJ is online now
post #44 of 52 Old 04-27-2013, 02:15 PM
MadMike03159
I ended up disconnecting all the sensors from the motor and draping the whole wire harness over the windshield. Not sure if this is the best method but it's the only option I could see short of disecting the dash. Just trying to get the parking brake cable separated from the frame and the body and I should be homeward bound.
post #45 of 52 Old 08-30-2013, 08:30 PM
Rugby_3
For everyone that did this how long did it take you to remove the tub? I need to take my fenders off already and my hood needs some attention so I should do the tub as well when it's all apart. How long did it take to put it back on as well? Thanks
Rugby_3 is offline
A/C Removalů AR-Guy YJ Wrangler Technical Forum 11 11-03-2010 08:55 AM
Air Dam Removal liquidean JK Wrangler Technical Forum 8 09-11-2009 04:12 PM
Oil Pan Removal Help TjBryce TJ Wrangler Technical Forum 3 09-06-2009 05:21 PM
CPS removal seattlejeepster YJ Wrangler Technical Forum 0 03-01-2008 06:04 PM
HT Removal Sidewalkman YJ Wrangler Technical Forum 4 07-12-2003 08:14 PM
