Tub Removal - Page 2 - JeepForum.com
post #16 of 52 Old 10-28-2009, 10:36 PM Thread Starter
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
Originally Posted by YNOTA_YJ View Post
thanks left lane! that post was what i was lookin for. I am just a cheapy free member right now so i cant search unless i go to google, thats why i never found yours.. ha i will be switching to the 20 dollar one, just wanted to check the site out more before i did.
No problem mate.
If you go go advance search on Google, you can put in Jeepforum.com as where to search!
But shelling out the membership is worth it for all the other benefits too
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #17 of 52 Old 10-29-2009, 01:44 AM
HilltopperYJ
this will be helpfull whem i swap my new frame in (as soon as i get done sandblasting and por15 everything i can)
K Σ
A-E-K-Δ-B
ΜΟΛΩΝ ΛΑΒΕ!
HilltopperYJ is offline
post #18 of 52 Old 11-25-2009, 05:06 PM
brapwithit
Perfect! Just picked up a frame today. I know what im doing over the holidays. Ya right it will prob take months, idk why I can just leave stuff alone! Thanks for the post, headed to buy a case of PB blaster!
brapwithit is offline
post #19 of 52 Old 03-04-2010, 02:32 PM
coachchuck
PB blasted the crap out of the body mount bolts and still snapped 5 of them last night.
Chuck
Sold : 93 YJ, 33s, 4.1, HO 4.0, AX15, d300 flipped
Building 90YJ. 37s, 5.38, 350, 4L60, np241, d44-ARB, D60-spool
coachchuck is offline
post #20 of 52 Old 03-04-2010, 02:42 PM Thread Starter
leftlanetruckin
XJ on 37's
Oh oh.
They are easy enough to fix with the tub off though, and you will never have an issue with a seized bolt afterwards huh?
Martin
post #21 of 52 Old 04-07-2011, 09:39 PM
ddurant311
Tub Swapping
Just figured I'd post my question here about which tubs styles can be put on a YJ frame. I posted it on the main, but figured I might get a better response in here. So if anyone is interested, please reply and let me know which tub styles and how difficult the swap is. Thanks.
ddurant311 is offline
post #22 of 52 Old 04-08-2011, 09:35 PM Thread Starter
leftlanetruckin
XJ on 37's
Tub styles?
You mean a TJ tub onto a YJ frame?
If so, why?
Martin
post #23 of 52 Old 04-29-2011, 10:04 AM
tdewit
Martin
First of all, thank you for the great write-up. I did what you said and it worked very well. The only thing I would recommend to anyone thinking of removing the tub is, don't start without an impact gun. You will just damage the heads and have a hell of a time later trying to remove them once you buy the above said the above impact.
Another thing I tested after reading on the forum, broken chassis bolts can be easily be removed by heating the nuts with a torch, and the broken studs can be easily removed with a stud extracter, a vice-grip or a monkey wrench.
tdewit is offline
post #24 of 52 Old 04-29-2011, 04:58 PM Thread Starter
leftlanetruckin
XJ on 37's
Good observation tdewit, and one I took for granted
I use the impact so often, I totally missed mentioning it in the thread! It is just like working on the rig without a cold beverage at hand
Martin
post #25 of 52 Old 09-05-2011, 07:20 PM
Come On Comet
Just started replacing my 87 tub with a better one.
Come On Comet is offline
post #26 of 52 Old 09-05-2011, 07:40 PM
brentd711
Thinking of pulling my '90 tub off for some repair work. Will the nose come off as a clip?
brentd711 is offline
post #27 of 52 Old 09-05-2011, 07:55 PM
Endimar
I am doing the same. I need to replace both floor pans and do a lot of fabricating to replace rust. I want to say thanks for all the info it is a huge help and made simple for us.
My question is, it looks like the fenders have been bonded to the tub through welding and gluing. I can grind all this off but would you recommend pulling the engine first or just cutting as needed? I really don't want to pull the engine. If I do I will be forced to rebuild it because of my OCD.
Jeep is American for AWESOME!
Endimar is offline
post #28 of 52 Old 09-05-2011, 11:42 PM
timatoe
timatoe's Avatar
The fenders are bolted to the tub, unless someone changed it at some point during its life.
timatoe is offline
post #29 of 52 Old 11-11-2011, 06:00 AM
stanwithers
Good write up leftlane
from Sudbury Canada
stanwithers is offline
post #30 of 52 Old 11-11-2011, 08:52 PM Thread Starter
leftlanetruckin
XJ on 37's
from Sudbury Canada
Thanks!
Martin
A/C Removalů AR-Guy YJ Wrangler Technical Forum 11 11-03-2010 08:55 AM
Air Dam Removal liquidean JK Wrangler Technical Forum 8 09-11-2009 04:12 PM
Oil Pan Removal Help TjBryce TJ Wrangler Technical Forum 3 09-06-2009 05:21 PM
CPS removal seattlejeepster YJ Wrangler Technical Forum 0 03-01-2008 06:04 PM
HT Removal Sidewalkman YJ Wrangler Technical Forum 4 07-12-2003 08:14 PM
