Quantcast tub bedliner ?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > tub bedliner ??
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFREE shipping on Rugged Ridge Soft tops @thejeephut.com
Old 03-12-2007, 05:12 PM   #1
MonsterMudder2
tub bedliner ??
i am about to do the inside of the tub with herculiner. my ? is, is that in my research after preping the tub via sanding it and cleaning it, everyone recommends to wipe it down with acetone, can you use other household products such as rubbing alcohol or nail polish remover to do the wipe down?
MonsterMudder2 is offline   Reply With Quote
Old 03-12-2007, 05:25 PM   #2
mean90yj
Yota Recovery Specialist
mean90yj's Avatar
basically you use the acetone to remove any grease smudges from the tub, that is usually the reason why you shouldn't touch the tub after using acetone because when you apply the herculiner, it will get a gooy look and wont set properly on that spot. I am assuming yo could, the problem with rubbing alchohol is that it will vaporize too vast, if you have any mineral spirits that would probably work. don't take my word for this though, im not 100% sure. Good luck with it. tell me how it goes i am planning to do mine very soon.
'90 I6 258 w/ Weber 32-36 Carb.
32" BF M/T's with cragar rims
5" BDS springs, MORE greasable shackles, XJ driveshaft, AA SYE kit, RE SS brake lines. Bilstein 5150's, 255/70 valving all around, 14" travel in front, 10" in rear.
~Enjoy>>> http://youtube.com/watch?v=nQCIXoBqpc0
JF MOTO>>>>"Ban a tard...save a life" <<<contributed by leftlanetruckin
OMNIPOTENCE...gotta get me some of that
mean90yj is offline   Reply With Quote
Old 03-12-2007, 05:56 PM   #3
ZIMSJEEP
The amount of alcohol or nail polish remover you would need to do the tub would cost you 10x more then a can of acetone or MEK. I wouldn't recommend using anything other then what herc's instructions say. You can pick either of the 2 up in any hardware store.
zim
[B]95 [COLOR="White"]White[/COLOR] YJ 2.5L [/B]
[SIZE="1"][B]3.5" Fabtech lift, 5/8" MORE Boomerang Shackles, 33x12.5 Mikey Thompson Baja Claws, MT 15x8 Classic II Alloys, JKS swaybar disco's, Rancho RS 5000 stablizer, Skyjacker Hydro 7000 shocks, Warn Bumper w/ pre runner, On board air, Grant Wheel, PIAA Windshield mounted lights, Herculined Interior[/B][/SIZE]
[COLOR="DarkOliveGreen"][I][SIZE="2"][B]PM me if you want to go wheeling on Long Island[/B][/SIZE][/I][/COLOR]
ZIMSJEEP is offline   Reply With Quote
Glock Forum
