TSL swampers or MT bias Baja Claws - JeepForum.com
post #1 of 5 Old 01-21-2002, 08:06 AM Thread Starter
JACKED
I want one or the other, I am going to go with a 33x13 on 16 inch rim with the TSL's or a 33x13.5 on a 15" rim with the claw, if u guys had to pick one which would u go with, and is 16 inch rim to big. I have always run 15" so any info will help thanx
Justin
93 YJ 4.0L 5 speed. 3" body and 4" suspension lift. 35x12.5 MT tires.
JACKED is offline
post #2 of 5 Old 01-21-2002, 11:28 AM
osburn
osburn's Avatar
Which TSL? All the Interco tires are called TSLs (Three Staged Lug). If you're talking about a Jeep that sees a fair amount of pavement, I don't think I'd consider bias ply anything. The radial Intercos really don't last very long on the pavement. I know mine sure aren't gonna be around much longer. But I doubt the baja claw has much pavement pounding life in it either. We sorta need to know your priorities to help much.
Matt Osburn
Score 1032
osburn is offline
post #3 of 5 Old 01-21-2002, 02:49 PM Thread Starter
JACKED
The tires I buy Need To be great on Loose rocks, Solid Granite, Deep mud and wet roots.
these are this is the TSL tire I want http://www.4wheelparts.com/product2....s=INTE&cat=TIR Hopefullly That is more helpful, Thanx.
Justin
JACKED is offline
post #4 of 5 Old 01-21-2002, 03:19 PM
osburn
osburn's Avatar
Well that's a good tire for what you described. Might even consider the Boggers if you're not concerned about the pavement. Those are likely to be the absolute best in the environment you're describing.
Matt Osburn
Score 1032
osburn is offline
post #5 of 5 Old 01-21-2002, 03:43 PM Thread Starter
JACKED
I run a 35" tire now on 15' rim and am going down to 33"s. well the tire I want only comes in 16" rim so am i only Gaining an inch of clearence btween my tires and my fenders.
JACKED is offline
baja claws killerbee TJ Wrangler Technical Forum 8 01-20-2006 02:34 PM
31in baja claws jeep jake TJ Wrangler Technical Forum 6 01-20-2006 12:56 PM
baja claws renegadeyj YJ Wrangler Technical Forum 2 09-14-2005 03:50 PM
will these baja claws fit? tAcHiTuP TJ Wrangler Technical Forum 4 12-10-2003 09:03 AM
baja claws ErikJordan YJ Wrangler Technical Forum 1 09-07-2002 06:41 PM
