Trying to see if I have a blown head gasket - JeepForum.com
post #1 of 15 Old 04-23-2013, 04:33 PM Thread Starter
nsgibson
I pulled the dipstick on my 94 YJ and saw chocolate milkshake up and down the stick. Figured I had a head gasket problem. Pulled the oil filter and saw similar consistency and color and not all oil was draining (was heavier than a new one). However, when I drained the oil, it looked normal consistency and color which has me rethinking things.
Also, it has not overheated. I have seen nothing on the temp gauge abnormal. The coolant was low in the overflow but the radiator was full. The only evidence was the dipstick and filter issues.
What should be my next step? i obviously don't want to jump into a HG replacement unless I am sure. Some folks I have talked to speculate it could be condensation, but I am not sure what causes that.
Thanks for any tips!
nsgibson is offline
post #2 of 15 Old 04-23-2013, 05:04 PM
roadyrob
1987 YJ Wrangler
2 things to do- !. do a compression test, if the head gasket is bad 2 cylinders next to each other will be very low. 2. fill out your profile so we know something about your jeep.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #3 of 15 Old 04-23-2013, 06:38 PM Thread Starter
nsgibson
Ok I will try that, read up on it, seems simple enough. However from my limited understanding, if the failure of the gasket occurred such that it opened passage from an oil port to a coolant port, and not to a cylinder, wouldnt that cause brown milkshake oil but not affect compression? Did not notice any power loss either. Still trying to learn about how this works....
Thanks!
Also updated some of my jeep info.
nsgibson is offline
post #4 of 15 Old 04-23-2013, 10:26 PM
SnowdogMarc
Another check is to pull the spark plugs out one at a time and see if any of them look like they were just installed. Water in the combustion chamber will act like a steam cleaner.
l We're here for a good time. Not a long time. So have a good time the sun can't shine every day.
l_______
/l ,[_____],
l---L -[]lllllll[]-
()_) ()_)--o-)_)____________VE6-SDG
SnowdogMarc is offline
post #5 of 15 Old 04-23-2013, 10:36 PM
rambo3489
A compression test will tell you if your head is blown anywhere. If it is blown between cylinders or to the waterways the compression will read low no matter what. But it will also read low if you have shot valves or rings. Although not as low.
If it's blown your exhaust will smell sweet. If it's bad you will see white exhaust.
I say run a compression test and check your plugs when doing so
Sent from my phone because I'm doing something "more important"
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
post #6 of 15 Old 04-23-2013, 10:39 PM
MaddBones702
If you take off the radiator cap and warm up check for bubbles in the water
Who knew where this would go?
MaddBones702 is offline
post #7 of 15 Old 04-24-2013, 05:57 AM
EABiker
If you only drive short trips not allowing the engine to fully warm up, the condensation will cause the oil to look like it does as well. Any chance this could be the case?
EABiker is offline
post #8 of 15 Old 04-24-2013, 06:01 AM
Siva283
Do the compression test. Its quick easy and will tell you alot.
Ask me how I know...
Siva283 is offline
post #9 of 15 Old 04-24-2013, 10:35 AM Thread Starter
nsgibson
ok, I will do the compression test over the weekend and check out the plugs also. Also, I put a quart of cheap, new oil in and then drained it, just to see what it would pull with it. It looked clean.
Also, the oil cap at the top of the valve cover didn't have any of the similar consistency oil thrown up onto it. Don't know if that would be common.
I typically drive it to work 1-2 days a week, 15 miles or so. It gets to steady state temperature.
Thanks for all the responses. I'll see what the compression test tells me and get back with you guys. -Nathan
nsgibson is offline
post #10 of 15 Old 05-12-2013, 02:37 PM Thread Starter
nsgibson
Ok, I had some delays due to work and weather, but I finally got to the compression check.
First, the spark plugs were all well worn (and needing a change, which I did later!). There was NOT one that looked any better than the others ("cleaned" by coolant).
Compression Results:
Cylinder 1: 100
Cylinder 2: 125
Cylinder 3: 120
Cylinder 4: 110
Cylinder 5: 130
Cylinder 6: 130
So, there is some spread across the cylinders, and I retested #1 since it was the low one, and confirmed the result. #1 is lower than I'd like, but there are not two low cylinders next to each other.
I had already changed the oil after the original finding on the dipstick, so I put in the new plugs and I drove around the neighborhood for 20 min. Temp was stable, no noticeable issues. After driving, I let it cool and rechecked the dipstick. It was clean as a whistle, as was the oil.
Given that the ONLY indication of a potential issue was the original dipstick finding (no overheat, etc), and looking at these results, am I crazy for thinking my YJ is ok? Anyone see anything in these data that I should be concerned about? I really appreciate any further advice.
nsgibson is offline
post #11 of 15 Old 05-12-2013, 06:47 PM
50rck
How long have you had your YJ? Just wondering if the PO could have overheated it once and put on a rebuilt head. Once a head gets warped, it will usually warp again. Only thing I can think of for you other than condensation like was posted before, but that would have to be a lot of condensation to be in all the places you describe.
1991 YJ, rebuilt 4.0L in spring 2009 at 234,000 miles, no lift yet, slightly offset wheels, 235/75/15 tires for now, rag top, sold the hard top. Over 35,000 miles on the rebuild and counting.
2006 Jeep Liberty. Nothing special, all stock.
50rck is offline
post #12 of 15 Old 05-12-2013, 08:38 PM Thread Starter
nsgibson
I have had it only one year. I could try emailing the PO to find out.
I am curious also if condensation could cause what I saw...however you say "condensation in all the places you describe"...I only saw this on the dipstick. It just seems weird if it is the head gasket since there are no other clear signs (at least not to me!).
Thanks!
nsgibson is offline
post #13 of 15 Old 05-13-2013, 08:43 AM
Que89YJ
You dont always get overheating with a head gasket problem. Just keep a eye on the coolant and the oil and see if you have a repeat. There is no sense in digging deeper until you see if it repeats after the oil change.
Que89YJ is online now
post #14 of 15 Old 05-13-2013, 09:22 AM
Jeepsr4me
Look down in thru the oil fill port. You will see pudding if gasket is bad or cracked head. If not change oil and keep eye on it.
compression test will not always show a bad haead gasket. Such as when between oil port and coolant. Just had that happen a few weeks ago.
Jeepsr4me is offline
post #15 of 15 Old 05-13-2013, 09:55 AM
Siva283
You can also get a test kit to test the coolant for the presence of exhaust gases if your that worried. As others have said the easiest and cheapest way is to keep a tight eye on your oil and coolant for a few weeks.
Siva283 is offline
