Trying to make a very capable trail jeep - JeepForum.com
post #1 of 5 Old 06-02-2010, 06:33 PM Thread Starter
highrolrcustoms
so after some serious consideration i want to turn the jeep into a very capable trail jeep. i was looking at lowering it down a little to make it a little more stable on off camber trails and hill climps. thought about adding tube fenders on the front and comp cut the rear to compensate for the decrease lift...so...
do i...
remove the 2" body lift....i am running a motor mount lift so not sure if i can remove the body lift
leave the body lift and take the 2.5" lift springs off and put stock springs on the soa
or any other ideas would be great!
95 yj juggy, backhalfed, 3 link front with 16" fox dual rate remote resi coilovers, 4 link rear with 16" fox air shocks, Monster Stak 2 Speed transfer case 4.33:1, full width ford 78/79 dana 60hp front axle with 538 gears and full spool, ford sterling 10.25 full width rear axle with 538 gears welded and disc brake conversion, 42x15 swamper tsl's on 15x8 Allied wheels 3.5" backspacing with DIY beadlocks, High Steer with 1.5x.250 dom tubing, Full Hydro steering, custom cage, rci 2161a fuel cell ,smitty xrc 8 winch, cv driveshaft, jk motor mount lift, racing seats with simpson 5 point harnesses
"THE MORE YA PLAY WITH IT.....THE BIGGER IT GETS"
highrolrcustoms is offline
post #2 of 5 Old 06-02-2010, 06:37 PM
warrior99
I would say just cut the body lift down to 1" or buy a new 1" if you can't cut it.
.________
/_l___\___\__
l__|___OlllllllO)
[z] . [z]--O-[z]
warrior99 is offline
post #3 of 5 Old 06-02-2010, 06:50 PM
YJ_Aaron
Cut down body lift and ditch the springs for stockers or stockers and waggys or xj's.
91 YJ rebuild! Rush to get it driving/wheeling.
YJ_Aaron is offline
post #4 of 5 Old 06-03-2010, 09:43 AM
Brown Dog
Vendor
Brown Dog's Avatar
There is no problem running MMLs without a BL. Read here:
Jeep Motor Mount Lifts (MML)
Brown Dog Offroad
Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep
100% HANDCRAFTED IN AMERICA
91YJ 2.5
Brown Dog Mounts and Engine Brackets (Serial Number 1)
2" BL
4.5" Superlift SL
AA SYE
35" GoodYear Mud Terrains
Conteract Balancing Beads
Bulldog front bumper
Best Top seats
"Family" roll bar
25 foot 1/2" log chain
No Top, No Doors (Best Top Safari)
Brown Dog is offline
post #5 of 5 Old 06-03-2010, 09:47 AM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Drop the body lift down to 1" and get some XJ or waggy springs to stretch the wheelbase out a bit. Comp cut the rear and tubes in the front. This should be a pretty nice setup for your suspension, but don't forget about all the other supporting mods as well.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
How capable is this jeep? wheresgeorgenow Wrangler General Discussion 35 02-23-2010 01:11 PM
Rubicon Trail can I make it plumber1 YJ Wrangler Technical Forum 7 11-03-2008 11:53 PM
Probably the most trail capable wrangler this planet has ever seen Swagger_Wagon Wrangler General Discussion 35 09-08-2008 10:44 AM
home made trail flags, what i need to make one. mudluva YJ Wrangler Technical Forum 7 03-18-2007 02:06 AM
What does it take to make a TJ capable offroad mccollum_007 TJ Wrangler Technical Forum 57 09-07-2006 06:59 PM
