Trying to fit new tail pipe - JeepForum.com
post #1 of 5 Old 07-10-2001, 11:09 AM Thread Starter
jmsjeep
I am trying to get in a new tail pipe and I cannot move it back far enough to get it in the muffler because it hits a bar which is connected from the frame to the opposite side on the axle. Do I have to remove this or am I not seeing something? Do I even need this bar? is this an antisway bar? If I take it off will I stray all over the road?
Thanks for the help
I wonder were that dirt road goes?
'89 YJ 4 banger all stock, replacing all the worn out guts first, 97 grand cherokee limited
jmsjeep is offline
post #2 of 5 Old 07-10-2001, 11:24 AM
JPFREEK
JPFREEK's Avatar
Sounds to me like you are hitting the Track bar. There are different opinions on whether you need this or not, I removed mine when I installed my lift and never noticed it was gone. Keep in mind that I also drive around completely disconnected too! I say remove the track bar. Option #2 would be to remove the muffler and slide the bar in that way.
-Pete
'91 YJ
JPFREEK is offline
post #3 of 5 Old 07-14-2001, 11:40 AM
Razskidoo
I purchased a Black Cat tail pipe and muffler . It was tricky to install the tail pipe over the track bar .
I had to raise the Jeep until the rear wheels were off the ground (that cause the track bar to drop a little)
Then I had to feed the tail pipe from the driver side over the track bar then slide the pipe into position.
It took a few tries until I was able to get it in place.
Make sure you insert the tail pipe far enough into the muffler to clear the track bar (not much room)
Note- if you have new shackles bolts for you springs MAKE SURE THE BOLT HEAD IS ON THE INSIDE! (If the threaded end is inside it will hit the tail pipe)
I do a lot of highway driving so I kept the track bar on. (Good for sudden turns and uninspected stops) keeps the Jeep from being top heavy! But not so good when 4 wheeling! Itís your call!
92 Wangler ,I-6 ,3"lift, 32x12.5
Razskidoo is offline
post #4 of 5 Old 07-14-2001, 11:52 AM
Razskidoo
It's a TFX KAT-BACK system
post #5 of 5 Old 07-14-2001, 11:25 PM
Tonka
2015 JK Wrangler
Run the passenger side only up a ramp(or Jack up the driver's side using the frame and jackstands as high as needed)
98 TJ
90 MJ short bed converted to 4x4
90 XJ 2 dr 4x4
Tonka is offline
YJ Tail Pipe iowajeepers YJ Wrangler Technical Forum 16 12-17-2009 03:06 PM
Cut tail pipe off??? 1993sahara YJ Wrangler Technical Forum 21 08-21-2009 10:15 PM
tail pipe cpundsack YJ Wrangler Technical Forum 12 08-06-2009 06:31 AM
Tail Pipe TJ TRunner TJ Wrangler Technical Forum 9 01-12-2007 11:49 AM
HELP on jeep tail pipe 95YJDAVE YJ Wrangler Technical Forum 15 11-18-2006 12:54 PM
