Trying to decode this engine - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Trying to decode this engine
LJ Suspension Systems from Clayton Off RoadEngo winches available at www.rockridge4wd.com! Free shippThe Original 3/8" Ruffstuff Diff Cover!
Unread 05-19-2014, 04:05 PM   #1
meangene21
I would like some help decoding this engine.. I have found on this forum, this link;
http://street2mud.com/webfiles/AMC%20Engine%20codes.pdf
This link is great BUT I am not sure what they are calling the left and right side of the motor. Passenger side or driver side? The reason I ask is because I am confused as to what I see. I see the PAD and it appears to have 3z0-x08 tagged on it. I do not believe I see it on the above link. Anyone? This code was found on the passenger front side of the motor.
Thanks !
meangene21 is offline   Reply With Quote
Unread 05-19-2014, 04:15 PM   #2
Old4X
1990 CJ7
The engine build code is stamped (not cast) into a machined flat on the block above the distributor
Rust free YJ for sale. Need more room in barn.
Old4X is online now   Reply With Quote
