TrueTrac, Axle Disconnect and Dana 30 - Page 2 - JeepForum.com
post #16 of 25 Old 03-10-2009, 07:17 AM
Scott91
My 91 also has no C-Clip in the front.
Scott91 is offline
post #17 of 25 Old 03-10-2009, 07:24 AM
wendell
1987 YJ Wrangler
You can get the about the same performance from a tru-trac as a locker unless you have a front wheeled jacked in the air all of the time. With the tires planted the tru-trac pulls like a train and is nicer on the street. Even if you do jack up a tire, just apply light brake presure and both tires will pull together like a locker. I've played with the tru-trac for years, it's a great unit. Unless your a hardcore rock crawler, it's all you need. I run the TT in the front and rear and it makes for one caplable off roader with good strret manors. A totally locked front and rear is over kill unless your into extreme rock crawling. If you like trail riding and enjoy driving your jeep on the street, the TT is more than capable, it also strengthens the diffs unlike the lunchbox lockers. The TT doesn't pop and jerk and still keeps the jeep street friendly while still allowing it to climb tree's off road.
1987 wrangler, 258 I-6, 5-speed.
2007 liberty sport 4X4, automatic
2009 ford ranger 4x4 FX4 OFF/ROAD, 5-speed
wendell is offline
post #18 of 25 Old 03-10-2009, 03:09 PM Thread Starter
airportdave
Either Flyin' or Jeepin'
airportdave's Avatar
2010 WK
Thanks again for all the great info!! Based on this forum and some other feedback, I have a new set of one piece front axle shafts on order, along with a disconnect block-off kit. As soon as Uncle Sam sends me back my money, I hope to get my TrueTracs and new 4.10 gears installed!
2010 Grand Cherokee Limited Hemi Q-D II, OME MD, 265/70/17 Hankook ATM's, HemiFever Tune
airportdave is offline
post #19 of 25 Old 03-10-2009, 03:22 PM
Castr8r
Yer gonna like it! I put a TruTrac in my d30 when I regeared to 4.88s. I eliminated the disconnect with a solid axle, and can't tell it's there on the street. When I get a wheel lifted or on a low traction surface, then a light foot on the brakes will "lock it in". Works great!
Castr8r is offline
post #20 of 25 Old 03-11-2009, 07:13 AM
wendell
1987 YJ Wrangler
I don't know why more people don't use the tru-trac, it's a strong gear driven lsd with features of a locker. It's a great choice for the kind of wheeling a lot of us do. I've had both the D-locker and TT and really perfer the TT because of it's street manors and it doesn't disapoint off/road.
wendell is offline
post #21 of 25 Old 03-16-2009, 10:33 PM
88yj4.2
true trac
I have this set up, and it works just like an open diff (with a little trick), when the vaccum dico is open.
you need to open the case and remove the convex spring washer that preloads the gears, without preload it works just like an open diff with one axle disconnected. nothing spins. trade off you don't have preload, (just like all the TT for a cclip axle), just use the brakes some now and then to lock it.
the small u joint 88 89 axle uses the c clip the later one with bigger u joints does not.
I have used this setup for a couple of years now, without a problem, have inspected the diff a couple of times, and i havent seen any metal shavings.
4.2 rocks....if you know how to build it.......
88yj4.2 is offline
post #22 of 25 Old 03-16-2009, 10:37 PM
jeeepguy
jeeepguy's Avatar
Now THIS is good tech! Best tip I've seen in a year. Nice post and thanks for the great tip.
"Si Vis Pacem Para Bellum"
"Great danger lies in the notion that we can reason with evil"
Doug Patton
...We use words like honor, code, loyalty. We use these words as the backbone of a life spent defending something. ...I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it. I would rather you just said thank you, and went on your way, Otherwise, I suggest you pick up a weapon, and stand a post...
I bought the HI-WAY BLASTER HORN that's 139dB and every time I honk the horn an Angel dies.
Revelation 13:16-18
16 - He causes all, both small and great, rich and poor, free and slave, to receive a mark on their right hand or on their foreheads,
17 - and that no one may buy or sell except one who has the mark or the name of the beast, or the number of his name.
18 - Here is wisdom. Let him who has understanding calculate the number of the beast, for it is the number of a man: (Real ID and RFID chips)
Think about it...
jeeepguy is offline
post #23 of 25 Old 03-23-2009, 06:52 PM
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
I just drove a "road" through the Idaho Panhandle that we thought was an all-year road. The farther we got the worse is got- plowed dry, plowed mud, only mud, snow covered at 3300 feet, deeper snow at 3800 feet... first snowmobile/quad trails then...
We started to have troubles keeping centered on the trail and had to back out. Some distance until we could do a 7 point turn!
The story I'm telling is that the posi and front TT were awesome. I've got BFG 33s and a 2.5 lift. What a gas. Talking about a gas, does the Vette engine spoil a person in the mud! The YJ drove like it could go anywhere.
The New Hybrid Scrambler Build :-)
The old '87 YJ LT1 350 Build
jeepsterjc is offline
post #24 of 25 Old 08-24-2011, 06:49 PM
The_Norm
My 89 Wrangler appears to have the center axle dropping into the truetrac. It didn't do it for 17 years, now when the vac-disco engages, it pushes the shaft into the differential. I read where the Toyo guys put a spot weld on the splines to prevent this exact problem. The truetrac has bee great (up until now). With the vac-disc open, you can't feel anything, just like an open diff. If I can't find any other problems, it's getting welded... just 2-3 spots.
The_Norm is offline
post #25 of 25 Old 08-24-2011, 08:18 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Why not just go with one piece shafts? I put my truetrac in the rear and couldn't be happier...
Luck Favours The Prepared
Anticanman is offline
Dana 35: Truetrac & chromos? 2000GrayTJ TJ Wrangler Technical Forum 19 02-11-2010 01:20 PM
dana 30 axle disconnect satchmoe YJ Wrangler Technical Forum 5 10-23-2009 01:14 PM
Questions about a front Dana 30 axle w/ vacuume disconnect FlyersPh9 YJ Wrangler Technical Forum 5 10-23-2008 12:51 AM
Dana 30 w/ Axle Disconnect Exploded View Jim93YJ YJ Wrangler Technical Forum 8 06-25-2008 09:20 AM
Detroit Truetrac In Dana 35?? kowalsy YJ Wrangler Technical Forum 11 02-05-2005 03:13 PM
