TrueTrac, Axle Disconnect and Dana 30 - JeepForum.com
post #1 of 25 Old 03-09-2009, 05:10 PM Thread Starter
airportdave
2010 WK
OK, I've looked everywhere for a consistent answer to this question, but haven't received one. Why is it "not recommended" to put a Detroit TrueTrac in a '95 Dana 30 with the axle disconnect?
The follow on question, is can a TrueTrac be run up front in my '95 YJ with the stock axle disconnect system, and what, if any handling or other issues can I expect? I'd love to upgrade the front axle entirely, but the money tree in our yard died earlier this year.
We use our Jeep on both pavement and for mild wheeling.
2010 Grand Cherokee Limited Hemi Q-D II, OME MD, 265/70/17 Hankook ATM's, HemiFever Tune
airportdave is offline
post #2 of 25 Old 03-09-2009, 05:50 PM
95 Lowbuck
The Trutrac works great in the Dana 30.
You just have to accept that your front D.S. will
be turning all the time as it would with any Locker or L.S.
regardless if you run an axle disconnect or not.
Some people have had good luck running the stock D.S.
after balancing it, but some like me had to go to a C.V. type
D.S. to get rid of vibrations. (The real problem)
As for handling problems, I have them F&R and it drives like
I'm open untill you give it alot of gas in a turn, and only the rear chirps.
95 Lowbuck is offline
post #3 of 25 Old 03-09-2009, 05:54 PM
sitdwnandhngon
1987 YJ Wrangler
It seems like a waste of money to me. You can get much better performance from a lunchbox locker and it costs alot less.
If you want an lsd for the rear though they have great street manners.
I can't bear the thought of losing, I dread the attention winning brings
Originally Posted by northjeep View Post
4.2 has 0.2 more!
sitdwnandhngon is offline
post #4 of 25 Old 03-09-2009, 06:09 PM
shaggyjim
shaggyjim's Avatar
I run one in my D44 and love it. Ya its not the cheapest way to go but I can run on the street with my hubs locked and not tell. It the same setup the Military Hummers run if I rember right. Its a gear drive torque biasing differential that can use brake modulation with your auto trany very effectively.
Jim...
"That's more fun than watching a hippie get mauled by a bear!"
shaggyjim is offline
post #5 of 25 Old 03-09-2009, 06:17 PM
jeeepguy
jeeepguy's Avatar
I ran a D30, axle disco, TrueTrac setup on my ri for three years as a DD with ZERO issues. It is a great setup for a DD/occasional trail rig. And it is MUCH better than an lunchbox locker as it doesn't stress the front end when it locks up when you don't want it to on road and the on road manners are mcuh better as well.
I have several buddies running their rigs with that setup and they have zero problems as well.
"Si Vis Pacem Para Bellum"
"Great danger lies in the notion that we can reason with evil"
Doug Patton
...We use words like honor, code, loyalty. We use these words as the backbone of a life spent defending something. ...I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it. I would rather you just said thank you, and went on your way, Otherwise, I suggest you pick up a weapon, and stand a post...
I bought the HI-WAY BLASTER HORN that's 139dB and every time I honk the horn an Angel dies.
Revelation 13:16-18
16 - He causes all, both small and great, rich and poor, free and slave, to receive a mark on their right hand or on their foreheads,
17 - and that no one may buy or sell except one who has the mark or the name of the beast, or the number of his name.
18 - Here is wisdom. Let him who has understanding calculate the number of the beast, for it is the number of a man: (Real ID and RFID chips)
Think about it...
jeeepguy is offline
post #6 of 25 Old 03-09-2009, 06:41 PM Thread Starter
airportdave
2010 WK
Cool- thanks for all the input. I'm leaning towards giving it a shot with a balanced front DS. This vehicle for us is most a fun summer car and not a daily driver, so it sounds like a good option.
post #7 of 25 Old 03-09-2009, 06:43 PM
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
I'm running a TrueTrac up front with a used solid chromemoly front passenger axle off of Ebay for 24 bucks. The setup runs well. If the passenger side axle is disconnected I think the TrueTrac may get screwed up- literally. It would always wind up the TT on one side??? It just didn't seem like a smart thing to do so I put in a solid axle...
The New Hybrid Scrambler Build :-)
The old '87 YJ LT1 350 Build
jeepsterjc is offline
post #8 of 25 Old 03-09-2009, 06:47 PM
yjjason
X-Y-J-Con
yjjason's Avatar
you can get a junk yard tj axle & get rid of disco. just my 2 cents
yjjason is offline
post #9 of 25 Old 03-09-2009, 08:04 PM
JohnRodriguez
you cant run a trutrac with the factory 2 piece vacuum disconnect, because the trutrac has no way of installing the c-clip retainer in the passenger side. The inner shaft will slide in and out of the carrier. All you have to do is purchase a 1 piece axle for the passenger side.
89 Wrangler, 2.5L TBI, D30 Truetrac 4.56 gear front, Super 35 4.56 gears rear, 31" BFG Mud's, 15x9" weld racing pro-stars XP's, 2.5" rancho and 1.25" shackels, superior axles. rear wilwood disc brakes
2008 wrangler x unlimited. Stone white. Motech 5.3L LS Chevy
JohnRodriguez is offline
post #10 of 25 Old 03-09-2009, 08:08 PM
TSEJEEPERS
What c clip are you talking about here?
When I had the stock 30 in my YJ I had my axle shafts in and out many times but do not remember a c clip.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #11 of 25 Old 03-09-2009, 08:11 PM
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
the inner pass has a circlip on it to stop it from floating out
post #12 of 25 Old 03-09-2009, 08:28 PM
TSEJEEPERS
Where? At the diff?
post #13 of 25 Old 03-09-2009, 08:30 PM
95 Lowbuck
Must be the early ones because my '95 didn't have a "C" clip.
post #14 of 25 Old 03-09-2009, 08:38 PM
TSEJEEPERS
Better yet give me a parts number.
http://www.quadratec.com/advisor/jee.../axleYJ30F.php
post #15 of 25 Old 03-10-2009, 04:49 AM
yellow2kgt
I have also read about this C-Clip. However, neither the stock dana 30 that came with my 90 or the 94 Dana 30 I swapped in had a c-clip on either axle. Maybe it was 87-89????
1990 Jeep YJ 4.2
Howell EFI, BDS 3.5" lift, M.O.R.E 5/8" Boomerang shackles, 1" Daystar BL, 1" JKS MML, TFI, Crager soft 8s w 35" Dunlop Mud Rovers, Ford 8.8, 4.88s, Dana 30 E-Locker, Terra Flex SYE, Tom Woods CV shaft, Warn M8000.
yellow2kgt is offline
Dana 35: Truetrac & chromos? 2000GrayTJ TJ Wrangler Technical Forum 19 02-11-2010 12:20 PM
dana 30 axle disconnect satchmoe YJ Wrangler Technical Forum 5 10-23-2009 12:14 PM
Questions about a front Dana 30 axle w/ vacuume disconnect FlyersPh9 YJ Wrangler Technical Forum 5 10-22-2008 11:51 PM
Dana 30 w/ Axle Disconnect Exploded View Jim93YJ YJ Wrangler Technical Forum 8 06-25-2008 08:20 AM
Detroit Truetrac In Dana 35?? kowalsy YJ Wrangler Technical Forum 11 02-05-2005 02:13 PM
