~ True Neutral Plate ~ - Page 7 - JeepForum.com
post #91 of 110 Old 12-29-2013, 09:29 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
I'm thinking about the Tera 2-low for my case...
Be sure your 4wd indicator light is working. The 2lo kit puts the new 5 positions in the space of the old 4, so it can be tough to tell what it's in by feel.
Also, I looked earlier today and didn't see the NP231 version of the 2lo kit on their web site. I hope for you they still offer it.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #92 of 110 Old 12-29-2013, 09:33 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Thanks for the heads up, Don. It's not high on my priority list but if I find a source, I will report back.
Luck Favours The Prepared
Anticanman is offline
post #93 of 110 Old 12-29-2013, 09:43 AM
YJames90
YJames90's Avatar
http://www.discountjeepparts.com/pro...oducts_id/6130
My 2.5 to 4.3 swap thread
YJames90 is offline
post #94 of 110 Old 12-29-2013, 11:43 AM Thread Starter
RikRotorhead
I think it would be helpful if you can explain the reason for having a 2Low in your Jeep.
Is it something that really helps? And why?
What parts are needed? Any modification required to make it happen beyond parts?
The true neutral comes with it?
Zombies hate fast food.
RJC#512
RikRotorhead is offline
post #95 of 110 Old 12-29-2013, 12:14 PM
JeeperDon
JeeperDon's Avatar
To me, it's mostly to improve the ability to get out of the woods (off the desert for me now...lol). I also have a Warn Hub Conversion. If something explodes badly in the front axle, which is my most likely break point, I can flip the hubs off, go to 2lo, and still creep over things to get back to the trailer.
I did mine while the t-case apart for something else anyway, so the only short term overhead for having it was the bucks, and that pain is long gone and forgotten.
Web Admin for
post #96 of 110 Old 12-29-2013, 12:58 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
There are only two reasons I would ever consider getting the 2 low: dropping a boat in the water down a ramp and compensatin on steep driveways with these 36's and 4.10 gears. I would like to keep my clutch intact and sometimes there's a little too much traction in 4wd for me. I just need precise gearing in my daily driven jeep sometimes.
post #97 of 110 Old 12-29-2013, 01:44 PM
YJames90
YJames90's Avatar
I think having the locker in the rear and 700R4 with the 60:1 ratio from the torque converter on 4.10 grars while in L1 would be the same as the low kit?
YJames90 is offline
post #98 of 110 Old 12-29-2013, 05:08 PM
Louie4
I think the biggest advantage (that I've seen) is turning. With the area I typically ride in and especially in the mountains tight turns suck in 4wd or at least for me they do. I've also put my jeep back in 2 Hi for situations where I need to spin the tires to move the rear of the jeep over but I wouldn't mind the 2 Lo option for that as well.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #99 of 110 Old 12-29-2013, 05:37 PM
jbolty
jbolty's Avatar
What Louie said,
From what I've read 2LO is good for tight turns, or a situation where the front tires are either jammed or buried and you don't want to dig them deeper. Just get an Atlas and have it all. It's only money.
jbolty is offline
post #100 of 110 Old 12-29-2013, 06:10 PM Thread Starter
RikRotorhead
Originally Posted by jbolty View Post
What Louie said,
OK good to know....
I just ordered one of these....
Hope it was worth re-financing the house for...
RJC#512
post #101 of 110 Old 12-29-2013, 06:17 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Send your old one to
Anticanman
PO Box 343
Ripon, Ca. 95366
Thanks for helping feed the hungry.
post #102 of 110 Old 12-29-2013, 07:50 PM
Lemoore-on
Thanks Don, I will keep my eye out for the 2lo option. I had that capability in the Toyotas I had in the past, it can be real handy
Mike
92YJ with some stuff done to it.
Lemoore-on is offline
post #103 of 110 Old 12-30-2013, 12:58 AM
zte87
GIVE IT THE ONION
zte87's Avatar
I'm thinking about the Tera 2-low for my case and giving my TJ plate to a buddy of mine. He's been after one for years even after he got his trailer to tow the jeep.
Do it I love my 2low, so since I added 2low to my 232 I have true neutral?
zte87 is offline
post #104 of 110 Old 12-30-2013, 01:43 AM Thread Starter
RikRotorhead
Put your t-case in neutral, transmission in 1st gear, engine off of course (standard trans). Jack up the rear wheels. If you can turn the rear drive shaft and the front one doesn't stop it, you have true neutral.
In a YJ, the only time the front drive shaft is NOT connected to the rear drive shaft, is when it is in 2high. Neutral, 4low, and 4high all connect the shafts together in the t=case with the shift mode fork that is controlled by the shift mode plate.
RJC#512
post #105 of 110 Old 12-30-2013, 06:19 AM
Louie4
OK good to know....
Maybe the Atlas will outlast the house and in that case it's a win.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
92 YJ shuts off when in neutral ortiz2188 YJ Wrangler Technical Forum 3 07-09-2010 08:26 PM
slipping into neutral mideville TJ Wrangler Technical Forum 4 03-07-2010 05:43 PM
Anyone relocate ther license plate an have a spare license plate holder lying around? DeepSky JK Wrangler Technical Forum 7 11-29-2009 12:20 AM
Did I damage anything? (4WD Neutral + P) TheMatrix TJ Wrangler Technical Forum 3 01-08-2009 06:36 PM
4wd wont go into neutral at all wegotj TJ Wrangler Technical Forum 3 11-13-2007 06:04 PM
