~ True Neutral Plate ~ - Page 6 - JeepForum.com
post #76 of 110 Old 07-16-2012, 03:28 AM
cubewhiz
Originally Posted by Mean Max View Post
Yup. I paid $55 for a Matco pair, they're worth every penny.
Max
I just had my transfer case open to change the input shaft. A good pair of lockring pliers made the job SO MUCH EASIER than when I took it apart the first time. Worth every penny indeed. I got a pair of Cman at Sears for around $20 or so.
95 YJ with V8 going in, BDS 3.5" lift with MORE 5/8" boomerangs
Toyo Open Country M/T 33x12.50R15 on Cragar Soft 8 15x8 wheels
My new Jeep: 95 ZJ with 4.0L I6 (auto trans)
cubewhiz is offline
post #77 of 110 Old 07-16-2012, 03:35 AM
YJames90
YJames90's Avatar
Update:
Still working perfect
My 2.5 to 4.3 swap thread
YJames90 is offline
post #78 of 110 Old 06-14-2013, 10:11 PM
chschs
2006 KJ Liberty
Hate to bump an old thread, but I'm looking at purchasing one of these plates from Summit for flat towing my YJ, but I don't feel comfortable enough (or competent, heh) installing it myself.
Who could I take this to in the Southern California area to get done for a good price? I've never dropped the transfer case before but I've removed driveshafts no problem. Also, would the fact that I have an SYE matter at all?
chschs is offline
post #79 of 110 Old 06-14-2013, 11:59 PM
Why J?
Why J?'s Avatar
If you can replace a water pump you can pull apart a tcase.
Dig in that thing....man.
New Project "Pissed Wife"
Phase II 5.3L/4L60e then NV3550
Why J? is offline
post #80 of 110 Old 12-20-2013, 02:50 PM
Louie4
I am going to pull my t-case and tranny out after the holidays and I was wondering if I could yank the selector shift plate from a '97-'99 XJ and it be the "true neutral" plate I need?
On Summit it states the part is for a '97-99 TJ & XJ.
http://www.summitracing.com/parts/omx-1867632/overview/
Since I have a Pull-a-part up the road and more time than money, I was thinking about getting one from there.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #81 of 110 Old 12-26-2013, 06:35 PM Thread Starter
RikRotorhead
I am not sure if they are the same. Are the t=cases the same in the XJ and TJ in those years?
You might want to go tot he XJ section and ask around.
You can see here the differences in the two plates....
Zombies hate fast food.
RJC#512
RikRotorhead is offline
post #82 of 110 Old 12-26-2013, 07:20 PM
DirtKar
Maximum Effort
DirtKar's Avatar
I'm glad this thread was resurrected Rik. I meant to thank you for starting it as it was my source for installing my own when i did my SYE. Works like a champ.
Luck Favours The Prepared
YJOTM JULY 2014
DirtKar is offline
post #83 of 110 Old 12-26-2013, 08:26 PM Thread Starter
RikRotorhead
You are welcome. Mine is a home made plate and it still works perfectly too.
Glad you had success with it.
RJC#512
post #84 of 110 Old 12-27-2013, 06:30 AM
YJames90
YJames90's Avatar
Same here!!
YJames90 is offline
post #85 of 110 Old 12-27-2013, 02:17 PM
Louie4
I assume they are the same plate since the website list them for those years and models but that's all I know. I may just modify my plate as you did. Is there a template available?
Thanks again!
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #86 of 110 Old 12-28-2013, 08:16 PM Thread Starter
RikRotorhead
Thanks again!
I had a template someplace but I don't remember where i stored it.
I emailed it to somebody way back when. I can check my old emails.
Thing is, you need to be precise with putting the dip in and get the curves exact so it slides smoothly, and the dip has to be exact so it puts the fork in the right location to disengage the shaft between the gears.
I have made seven of them and they all turned out perfect.
If the vehicle is not your daily driver, just pull the t-case and the old plate out. If it looks like the one in the pic above exactly, which it probably does, then just order it then.
Pulling the t-case is pretty easy. Some 13mm nuts hold it to the trans, some lincage and cables.
Splitting the case is where you have to be careful, so as not to crack the case. Once it's split, the plate replacement is very simple. Re-assembly requres a tube of black RTV glue and someone to help you lift it back in.
Honestly, I've pulled my t-case four times, twice by myself. It's not that heavy, just awkward. Weighs maybe sixty to seventy pounds?
Posts 19, 30, and 47 in this thread contain important information for you.
The entire job is four beers long if it's cool outside. Nine if it's hot. .
RJC#512
post #87 of 110 Old 12-29-2013, 07:01 AM
Lemoore-on
This spring I am installing the Tera-low to my case, I want to do this mod at the same time. I flat tow often.
The case is not bad to remove, if you can bench press 65LBS you can do it
Mike
92YJ with some stuff done to it.
Lemoore-on is offline
post #88 of 110 Old 12-29-2013, 07:20 AM
Louie4
Thanks guys. I've taken out that t-case a few times and put in a couple SYE's. I may just get the plate from Summit and roll with that.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #89 of 110 Old 12-29-2013, 07:55 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
Add the Tera '2lo' kit, which has this fix already, and also has the 2lo part added. I did and don't regret the somewhat high price tag for the kit at all.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #90 of 110 Old 12-29-2013, 08:11 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I'm thinking about the Tera 2-low for my case and giving my TJ plate to a buddy of mine. He's been after one for years even after he got his trailer to tow the jeep.
Anticanman is offline
92 YJ shuts off when in neutral ortiz2188 YJ Wrangler Technical Forum 3 07-09-2010 07:26 PM
slipping into neutral mideville TJ Wrangler Technical Forum 4 03-07-2010 04:43 PM
Anyone relocate ther license plate an have a spare license plate holder lying around? DeepSky JK Wrangler Technical Forum 7 11-28-2009 11:20 PM
Did I damage anything? (4WD Neutral + P) TheMatrix TJ Wrangler Technical Forum 3 01-08-2009 05:36 PM
4wd wont go into neutral at all wegotj TJ Wrangler Technical Forum 3 11-13-2007 05:04 PM
