~ True Neutral Plate ~ - Page 2 - JeepForum.com
post #16 of 110 Old 07-25-2010, 07:21 PM
cubewhiz
It's a pretty quick install
cubewhiz is offline
post #17 of 110 Old 07-25-2010, 10:46 PM Thread Starter
RikRotorhead
Originally Posted by plym49 View Post
Thank you for posting this. We needed a thread with a single, concise explanation of True Neutral, and now we have it!
Perhaps this thread should be linked in the tech FAQ.
Thanks. I intend to put some pics in my first post of the actual plates in the t-case this week to show how it positions the mode fork sleeve.
Originally Posted by jamesx2 View Post
Thanks, as I was just reading the flat towing thread this morning. too bad I already did the SYE. If I had only known earlier
Bummer. The plate slides in very easily. But you have to split open the case again to get it in there. Means labor and another tube of black RTV.
Yeah, nothing to it for sure.
Zombies hate fast food.
RJC#512
RikRotorhead is offline
post #18 of 110 Old 07-25-2010, 10:53 PM
cubewhiz
Hey Rik,
I have a couple pics of the plate installed in the transfer case in my SYE album. Feel free to use any of them if it will help.
SYE Install pictures by cubewhiz - Photobucket
95 YJ with V8 going in, BDS 3.5" lift with MORE 5/8" boomerangs
Toyo Open Country M/T 33x12.50R15 on Cragar Soft 8 15x8 wheels
My new Jeep: 95 ZJ with 4.0L I6 (auto trans)
cubewhiz is offline
post #19 of 110 Old 07-26-2010, 06:24 PM Thread Starter
RikRotorhead
Hey Rik,
Thanks. I did find one in there that helps to explain it a little.....
Notice the pin of the rear mode fork is in the valley of the true neutral plate (A). This is the dip in the plate that allows the main shaft gear selector fork to drop to the position to allow the selector ring (B) to drop down below the front output chain drive gear (C). You see in the pic at (D) the ring is just below the gear. This allows this gear to spin freely on the shaft.
Without the dip in the plate, the ring would sit higher and cause it to be connected to the gears below it, thus spinning with them because the rear drive shaft is spinning the main shaft and those gears are directly connected to the shaft. Gear (C) spins freely on the shaft.
The pin in the slot of the plate (not visible in this pic) has not changed. It still dosconnects the transmission from the transfer case.
Does that make sense?
RJC#512
post #20 of 110 Old 10-16-2010, 01:50 PM Thread Starter
RikRotorhead
This should be a sticky.
RJC#512
post #21 of 110 Old 10-16-2010, 10:19 PM
'92 vegas YJ
i agree..... THIS SHOULD BE A STICKY
'92 vegas YJ is online now
post #22 of 110 Old 10-16-2010, 10:39 PM
jeepKY
Or at least put into the FAQ.
White/Spice 1995 Rio Grande 2.5L DD/Weekend Fun
2.5" RC 31 x 10.50 Toyo A/T Open Countries
Eastern Kentucky University
jeepKY is offline
post #23 of 110 Old 10-17-2010, 07:47 PM Thread Starter
RikRotorhead
Maybe a stinky?
RJC#512
post #24 of 110 Old 10-18-2010, 10:37 AM
timatoe
timatoe's Avatar
Originally Posted by RikRotorhead View Post
Maybe a stinky?
Maybe a stinky fact in the FAQ?
You have a PM.
timatoe is offline
post #25 of 110 Old 10-18-2010, 11:53 AM
Louie4
Is there a way to obtain a 2LO option while in the t-case? I like the writeup and I'll definitely do it when I rebuild my NP231.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #26 of 110 Old 10-18-2010, 12:20 PM Thread Starter
RikRotorhead
I can't see how you could do it.
The slot in the plate determines the position of the forward mode fork. The forward mode fork determines high or low, as well as neutral from the transmission (centered between the high and low in the planetary gears).
It could probably be engineered but not with a simple change of a plate.
RJC#512
post #27 of 110 Old 10-18-2010, 12:20 PM Thread Starter
RikRotorhead
You have a PM.
you received a reply.
RJC#512
post #28 of 110 Old 02-21-2012, 09:13 PM Thread Starter
RikRotorhead
Bumping up this old thread....
RJC#512
post #29 of 110 Old 02-22-2012, 07:44 AM
oldtime_ironman
I lost a whole weekend looking for a thread like this once. Sticky this into the FAQ!!!Q!
oldtime_ironman is offline
post #30 of 110 Old 02-23-2012, 11:26 AM Thread Starter
RikRotorhead
Seems like it should be a sticky by now.
Here's a pic of the back of the t-case filler/drain holes........
The plug on the bottom of the t-case is NOT the drain, it's holding a spring and a pin.
RJC#512
92 YJ shuts off when in neutral ortiz2188 YJ Wrangler Technical Forum 3 07-09-2010 07:26 PM
slipping into neutral mideville TJ Wrangler Technical Forum 4 03-07-2010 04:43 PM
Anyone relocate ther license plate an have a spare license plate holder lying around? DeepSky JK Wrangler Technical Forum 7 11-28-2009 11:20 PM
Did I damage anything? (4WD Neutral + P) TheMatrix TJ Wrangler Technical Forum 3 01-08-2009 05:36 PM
4wd wont go into neutral at all wegotj TJ Wrangler Technical Forum 3 11-13-2007 05:04 PM
