has anyone tried the truck plugs from champion?im just wondering if i should switch back to the old regular champion plug or not. this morning jumped in raring to go to class and and started fine about five miles into it . started giving me crap. sputtering and loading up it seemed .probably the junk bbd carb but i dunno.i think bbd stands for back behind dumpster .
I've been running the Truck Plugs for over a year with no problems. Most people I know run these also with no problems. Sounds like it must be something else. HTH
Well, was it pouring out the black smoke? If so, your choke was probablely stuck, which is a common ailment of the BBD. If it was stuck for a few miles, then likely you also fouled a plug. Check 'em both.
As far as plugs go, I used the new Bosch Platinum split plugs. They work great, haven't had any hesitation or misfiring that I can tell of. Just don't forget the dielectric grease.
Well to each his own, I haven't had a single problem yet with them. Honestly if they are used in beamers I would assume they can't be all bad. Now if it was a kia or tempo.... hehe. Can't hurt to experiment with easily changeable hardware.
As far as I'm concerned a car plug and truck plug is the same thing, as long as they produce a strong spark it doesn't matter (unless you have some custom head with a different thread size tapped in). Maybe HIGH performance engines running extreme RPM and special fuel (premium plus gas only, methanol, etc) like a ferrari engine might need special plugs. Other than that the plug in a minivan or pickup should be the same thing (except obvious size differences) but the principle is the same.
I put in the expensive bosch plugs once and had a miss, worked on them for a minute, still missed. So I took them back and got Delco's if I remember right (Im partial to them). I hear good things about them though..........
I think the truck plug thing is just a gimic. I don't like champion plugs anyway. Bottom line, if they work they work, if they don't change them. Im with exfherci, sounds like a choke issue.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
