Trouble Removing My AX15 - Page 2 - JeepForum.com
post #16 of 21 Old 06-09-2010, 02:46 PM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
Originally Posted by Karma View Post
HI All,
We are not communicating. On my early AX15, the tranmission case and the bell housing are one piece.
Nope. Look for nine bolts inside the bell housing going through it into the trans. Where do you think the photos above came from? They are with the bell off. See the ring of holes? The upper photo still has the 9 big bolts hand spun in, besides the smaller bolts for the retainer.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is online now
post #17 of 21 Old 06-09-2010, 02:56 PM
monkeyhouse
Originally Posted by UltimatE View Post
I have never heard of the AX-15 and bell housing being a single unit. Can you post pictures?
X2 on the ax-15 ever having a bell housing that was one with the body, weird, but then again you also said you couldn't see the inspection plate bolts because they were covered in grease. Hey and easy on the hating there big fella, jeez.
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
post #18 of 21 Old 06-09-2010, 03:46 PM
ssyj94
If the trans doesnt have a removable bellhousing its not an AX15 at all its a Peugeot BA-10/5. Peugot on the left ax15 on the right.
My build:
ssyj94 is offline
post #19 of 21 Old 06-09-2010, 03:52 PM
monkeyhouse
You know I remember reading in a thread a while back here that There were BA-10's with non-removable housings
post #20 of 21 Old 06-09-2010, 05:54 PM Thread Starter
Karma
HI all,
I feel like a fool. You all are right. The bell housing is indeed separate. The tranny is so dirty that the seam between the tranny and the bell housing is invisible. However, the bolts inside the bell housing tell the truth just like you described.
I just got home from work and went immediately to the garage to check it out. I don't know about converting to an external slave. It looks like the bell housing would have to be replaced with one that could handle the additional clutch linkage, the external slave and a normal throwout bearing. Even so, it would be worthwhile.
So let me aplogize a thousand times. You guy's know what you are talking about and I'm still learning. I like to learn. Thanks for putting up with me.
Sparky
Karma is offline
post #21 of 21 Old 06-09-2010, 06:01 PM
monkeyhouse
HI all,
Sparky
Yes sir, I am pretty sure it was Don who originally pointed this out, but it really is a pretty easy conversion to the external slave. If you can do it, rebuild that ax-15 and convert, you have a nice spare or you can easily sell it, either way, you win. Plus, you get to do something really cool along the way, I love working on these things man! And I know you do too.
Trouble Removing Dash buddyfilek TJ Wrangler Technical Forum 3 03-18-2012 08:29 PM
trouble removing hard top kangarool TJ Wrangler Technical Forum 12 04-21-2009 02:12 PM
trouble removing 2" BL, need help langston.4 TJ Wrangler Technical Forum 7 11-25-2008 07:39 PM
Here is what I'm having trouble removing (mainly cause I don't know what it is) NEWtoTHEjeepLIF TJ Wrangler Technical Forum 73 08-12-2006 09:19 PM
Removing the AX15 rpickett YJ Wrangler Technical Forum 8 07-28-2004 08:11 PM
