trouble getting into gear from a stop - Page 4 - JeepForum.com
post #46 of 58 Old 04-10-2007, 07:59 PM
ufatbastehd
Originally Posted by yJ rod
Where does everyone get this redline tranny fluid? I've looked at Auto Zone and Advance and can't find it.
http://myoilshop.com/
ufatbastehd is offline
post #47 of 58 Old 04-10-2007, 08:23 PM
jay-h
Originally Posted by platinumjeep
ok that makes sense. it definately grinds when going into reverse. i have to try it a couple times just to get it in. it seems like it just started doing this after i replaced the fluid though. so how do i fix a dragging clutch? what exactly do you mean by a dragging clutch? thanks
If you are having reverse gear grinding it is NOT the fluid. At best changing the fluid will only mask the problem while you are still damaging your trans.
Dragging clutch can be linkage /master/slave in which case it can often be fixed from the outside. However if that does not do it, then it is the clutch disk, throughout, fork or pressure plate. The clutch must be removed to replace any of these items. it sucks but is better than trashing a good transmssion.
If you can't pin it down, I recommend you let someone with experience look at it.
jay-h is offline
post #48 of 58 Old 04-10-2007, 08:30 PM Thread Starter
platinumjeep
yes when you try to put it into reverse quickly, it grinds. if you move it in slowly, it does not. the guy that looked at it today said this is because reverse is not syncronized. does this sound right to everyone?
platinumjeep is offline
post #49 of 58 Old 04-10-2007, 08:38 PM
longdecember
nope no sycros for reverse
she's a real grand Rio Grande: 4" RE, 35" pro comp's, trail damage
longdecember is offline
post #50 of 58 Old 04-10-2007, 09:10 PM
trickle26
trickle26's Avatar
I had very similar symptoms platniumjeep about a month ago and a new master cylinder cleared up the problem in my 94' AX15. I decided to go for it after some people on this board helped diagnose my similar symptoms. Not a bad project... Just mentioning it to you in case the problem gets worse. Mine finally left me stranded and I couldn't even get it into first gear.
I know you have heard it enough... but, another plug for Redline...I had no idea what the previous owner used for fluids in my YJ and I switched over the tranny to Redline MTL after I had driven it the first 400 miles. Much smoother shifts through all of the gears.
You can read up on Redline MTL here:
http://www.redlineoil.com/products_g...p?categoryID=7
summitt racing sells redline and was reasonably priced.
97' ZJ Limited V8 - 5.2 liter
94' YJ 4.0 ho -SE -
past jeeps: 89' YJ
87' YJ Laredo
88' YJ Sahara
90' XJ Limited
trickle26 is offline
post #51 of 58 Old 04-10-2007, 09:40 PM
ErikJordan
Pimp Hand
ErikJordan's Avatar
i order mine on line.
___________________________________________
What is all of this talk of Savvily designed products?
ErikJordan is offline
post #52 of 58 Old 04-11-2007, 01:10 AM
jcreelman
Clutch problem. Not fully releasing, so problems with master/slave cylinder, clutch linkage, clutch itself, or even oil on the disc will cause it not to release fully. Air in the system will cause it not to release. Changing the oil in the trans might make it easier to get into gear, but still does nothing for the not-fully-releasing clutch. Bleed it if possible, check all you can for leaks, bent/loose parts, then either take the clutch out yourself, or find someone who can.
jcreelman is offline
post #53 of 58 Old 04-11-2007, 07:07 AM Thread Starter
platinumjeep
yea im still gonna look into it this weekend.
post #54 of 58 Old 04-11-2007, 06:24 PM
James04TJ
James04TJ's Avatar
Originally Posted by Jimbager
I used the 75w-90 Gear Lube GL-5 from Amsoil...should I use something else
If you are using one of the 75w-90 GL-5's you are indeed using the wrong fluid. The ONLY AMSOIL product that is designed for use in the AX-5 and AX-15 is their Synthetic Manual Transmission and Transaxle Gear Lube 75W-90 API GL-4 (MTG).
*2004 TJ (Mine)* 1984 CJ-7 Buggy Project (Mine)* 1977 CJ-7 (Hers)*2005 Nylint Crawler (The Kid's)
James04TJ is offline
post #55 of 58 Old 04-12-2007, 01:20 AM
Tshark299
Tshark299's Avatar
1987 YJ Wrangler
I agree completely. There is a problem with your clutch, though it is one you can live with, which speaks highly of your tranny guy since he's obviously not trying to rip you off.
my '95 XJ with a supposedly new clutch installed by a shady trasmission shop has the same symptoms, in that the clutch drags if it heats up too much after a few stop and gos. After driving it a while I've learned how to compensate for it, and am not worried it will fail on me, but still it's not the way it's supposed to be.
My '87 YJ with the original clutch and hydrolics has none of the same symptoms my XJ has. If you can't drop the transmission and remove the clutch yourself I'd just deal with it until it's time for a new clutch.
- 4.0L, AX-15, NP231, 4.10s: 3.5" BDS, 31" Muds
- Donated drive train to the YJ, Parted out the rest
- Buick 225 V6: Painless Wiring Harness, Warn Overdrive & Hubs, 2" Lift, 31" Muds
Tshark299 is offline
post #56 of 58 Old 04-12-2007, 08:58 PM
eng4safd
Have a 95 yj w/ the exact problems and symptoms you are talking about. Usualy just come to a stop and keep the pedal stomped and it goes in to any gear w/ no problem. It only does it like you said when you come to a stop. Just change to moble 1 synthetic , shifts smoother but no cure for the probem. I think Im going to just adapt and overcome!!!
eng4safd is offline
post #57 of 58 Old 04-12-2007, 09:33 PM
trickle26
trickle26's Avatar
^^^don't switch to Mobil 1 synthetic gear oil as stated above. This is GL-5 and you don't want this. GL3 or GL4 is what you should put in the tranny.
94' YJ 4.0 ho -SE -
past jeeps: 89' YJ
87' YJ Laredo
88' YJ Sahara
90' XJ Limited
post #58 of 58 Old 04-12-2007, 09:37 PM Thread Starter
platinumjeep
thanks for all the good info guys.
im swapping out my fluid for redline and bleeding my clutch master cylinder this weekend. If it doesnt clear up after that, im going to just deal with it until i need a new clutch. ive been driving it everyday and im getting good at compensating.
97 5 speed will not go into gear at a complete stop fiveoaks TJ Wrangler Technical Forum 18 07-31-2013 03:26 PM
Trouble from stop in first gear Didley TJ Wrangler Technical Forum 6 05-13-2009 06:42 AM
Trouble with Stop Light Magnets JeepRocks86 TJ Wrangler Technical Forum 27 04-26-2009 03:12 PM
1st or 2nd gear from stop??? Coptrainer YJ Wrangler Technical Forum 4 02-26-2006 11:25 PM
trouble shifting from stop chris1201 TJ Wrangler Technical Forum 1 01-16-2005 07:27 PM
