Trouble accessing u-Joint zerk - JeepForum.com
post #1 of 6 Old 08-11-2011, 04:11 PM Thread Starter
Austin83
I've got a 93 Wrangler and I can't get my grease gun's nozzle to fit in the tiny spot that the zerk is located. I've got a standard grease gun with a flex tube, but the actual metal tip is too fat to fit into that location. What does everyone else here do? Should I grind down the tip on the nozzle, or remove that zerk and add a longer zerk? I really don't want to take the u-joint apart everytime I need to grease it. Thanks in advance.
Austin83 is offline
post #2 of 6 Old 08-11-2011, 04:32 PM
jbolty
jbolty's Avatar
take it apart one more time and replace the zerk with the flat needle type, then you can use the matching fitting to grease it. I have those everywhere, they are way harder to break off as well.
jbolty is offline
post #3 of 6 Old 08-11-2011, 08:05 PM
TSEJEEPERS
You can also use that adapter for your grease gun with a regular zert.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #4 of 6 Old 08-11-2011, 10:14 PM
EZAces
what joint is it on? If it's ont the t cace then you can put a cross that has the zirks on the caps.
EZAces is offline
post #5 of 6 Old 08-12-2011, 07:41 AM
pasinbuy
JBolty, you taught me something. I did not know about that zert. I always wondered how to use that attachment to my grease guns?
Well I be! I will be adding them to my arsenal.
How?
pasinbuy is offline
post #6 of 6 Old 08-12-2011, 08:04 PM
TSEJEEPERS
Just put the point of the needle where the ball is in the grease cert.
Push it in and hold it, pump the grease into it.
cv joint rebuild, correct placement for greasable u joint zerk fitting rutacon05 TJ Wrangler Technical Forum 5 10-31-2012 08:22 AM
What kind of lube (mini zerk) bolt is this? Should I ditch for normal one: U-joint SolidBrass TJ Wrangler Technical Forum 7 02-02-2011 10:48 PM
Installing new rear u joint with zerk fitting Obcean2 YJ Wrangler Technical Forum 17 02-08-2010 06:55 PM
grease zerk on passenger side lower ball joint but not driverside? micklock TJ Wrangler Technical Forum 5 09-06-2009 09:45 AM
front DS u-joint zerk locality (yeah, I searched) GringoLoco TJ Wrangler Technical Forum 2 07-08-2007 06:04 PM
