trimming - JeepForum.com
post #1 of 6 Old 09-12-2001, 07:58 PM Thread Starter
91 sahara
trimming
Im curious in what method incl. tools works best for trimming painted stock fender flares?
any info or pictures would help.
91 sahara 4.0 5sp hardtop 31's on 15x8 m/t classic 2's rock-it air intake and k&n so far.
91 sahara is offline
post #2 of 6 Old 09-12-2001, 11:39 PM
bigblueyj
just how much trimming are we talking about ?
bigblueyj is offline
post #3 of 6 Old 09-14-2001, 07:48 PM Thread Starter
91 sahara
minimum amount just to get extra clearance till i add a lift.
post #4 of 6 Old 09-15-2001, 09:26 AM
osburn
osburn's Avatar
I bought a set of TJ flares. Set them up against the fender, marked where the cuts needed to be, then cut along the line using a plasma cutter. Used a grinder to smooth and finish.
Matt Osburn
Score 1032
osburn is offline
post #5 of 6 Old 09-18-2001, 05:36 PM
glm 87 wrangler
A set of extra wide flares may prove better
will also help keep mud from flying in when you have your windows down and or doors off.
I have an 87 wranger with 31x10 on them and they work great with no lift.whith stock the weels stuck out more and i would get showered
with mud.Now less mud on me and more fun.Just one thing to add want help with the splash over so go slow and drive hard.
Gary 87 Wrangler 4.2 258 with weber carb and TFI upgrade.
31/10.5 and Nutter bypass!
glm 87 wrangler is offline
post #6 of 6 Old 09-18-2001, 07:17 PM
osburn
osburn's Avatar
Honestly, I'd love to run wider flares for just the reason you mention. But I'll be damned if I can keep normal width flares from getting discombobulated in the rocks. Can't imagine what I'd do to extended flares.
Matt Osburn
Score 1032
osburn is offline
Trimming YJ Flares ticconi YJ Wrangler Technical Forum 33 01-25-2009 02:59 PM
How much trimming for TJ flares on a YJ? chadroc YJ Wrangler Technical Forum 1 11-10-2008 07:02 PM
Trimming fenders TheDuke05 TJ Wrangler Technical Forum 23 10-09-2006 09:04 PM
trimming for 2''re bb, jks 1.25'' bl and 33s Gabe TJ Wrangler Technical Forum 16 07-27-2006 08:42 AM
Fender trimming TellyDSP YJ Wrangler Technical Forum 11 07-20-2006 05:28 PM
