tried jumping the battery and saw smoke - JeepForum.com
post #1 of 17 Old 04-14-2008, 09:12 PM Thread Starter
blamejane2
I'm hoping this is not going to hurt much, but...
I had a dead battery after leaving my lights on all day. I then tried jumping my jeep with my our dodge 3500 diesel. Next thing I see is smoke from the driver's side firewall. Immediately disconnected the jumper cables.
Then tried jumping it with our 92 f250, which did charge the battery (without smoke) but the engine wont start. I cranks but nothing more.
Also, I can't get any engine codes. After the sequence of on-off's I get a steady engine light.
Any ideas?
Valerie
blamejane2 is offline
post #2 of 17 Old 04-14-2008, 09:14 PM
Brandon_YJ
1987 YJ Wrangler
Fried computer or something similar? (not up to par on computer controlled vehicles)
Please tell me you had the cables connected correctly, and not pos->pos / neg->neg
Originally Posted by Mean Max View Post
I think I'll keep the YJ. But can I talk you into taking the wife?
DISCLAIMER: I (usually) browse the web using
in a (text only)
. Which means I do not have image viewing support. So if you get confused by my seemingly inability to comment on your pictures, emoticons, etc; now you know why.
If you're still confused
to see how I view the forum.
Brandon_YJ is offline
post #3 of 17 Old 04-14-2008, 09:22 PM Thread Starter
blamejane2
yeah cables were fine...
It seems so close to starting, but I'm guessing my PCM is now fried. I don't get why this would happen.
post #4 of 17 Old 04-14-2008, 09:28 PM
provinT13
This happened when this girl was trying to jump her XJ in the parking lot. Her idiot boyfriend put the cables on the wrong ends and the batteries of both cars started to smoke, luckily no damage was done.
2 Hands Working Do More Than 1000 Hands Praying
provinT13 is offline
post #5 of 17 Old 04-14-2008, 09:44 PM Thread Starter
blamejane2
the smoke definitely occured where the PCM is located, I'm just hoping that it won't need to be replaced. Anyone got experience replacing this? What about cost?
post #6 of 17 Old 08-14-2009, 08:00 PM
92yjwrangler
same symptoms!! it like cranks and cranks but no start
92 wrangler yj 33in Dunlop Mud Tires
pioneer head unit and front speakers sony amp with 2 rear 6x9 alpine pro series speakers
92yjwrangler is offline
post #7 of 17 Old 11-05-2011, 09:40 AM
kriv
Just had this happen to me.
kriv is offline
post #8 of 17 Old 11-05-2011, 09:44 AM
77_waggy
Changing the PCM is not hard but they are not cheap. Call the dealer for a price and also try a local junk yard. By the way is there a fuse box where the smoke came from?
77_waggy is offline
post #9 of 17 Old 11-05-2011, 10:09 AM
kriv
There is not a fuse box in the engine compartment. There is a fusebox that matches up with it on the interior of the car.
kriv is offline
post #10 of 17 Old 11-05-2011, 11:47 AM
bkn1971
A guy I worked with had the the same symptoms with his jeep and had a shop change his PCM and after about a month of messing with it the shop told him they no longer wanted to work on it so he had it towed home and started going thru the wiring leading to the PCM all it was for him was a corroded connection. I would check the fuses and the wiring in the area of the smoke before buying a new PCM.
bkn1971 is offline
post #11 of 17 Old 11-05-2011, 11:54 AM
kriv
Thanks bkn.
kriv is offline
post #12 of 17 Old 12-29-2011, 12:26 PM
kriv
So I replaced the battery and 4 fuses that were blown out, traced the electrical, but couldnt find any more issues. That doesn't mean they aren't there, just that I couldn't find them. The jeep still will not start, but at least it isnt completely dead anymore. I guess it is time to order that pcm.
kriv is offline
post #13 of 17 Old 12-29-2011, 01:36 PM
jmmorgan82
2009 JK Wrangler
Had the same smoke issue happen to me. My no-start condition was caused by some pretty bad cables. After replacing those, it started right up and even though there was smoke, my Heep has had no issues.
jmmorgan82 is offline
post #14 of 17 Old 12-29-2011, 02:41 PM
Reddy89
Disconnect your battery for several minutes, this will make the computer reset, reconnect it and try to start it.
Reddy89 is offline
post #15 of 17 Old 12-30-2011, 04:32 PM
JWELK
I've seen them on ebay for 40 bucks.
Trust me, you are not the first, nor will you be the last. For the future, red jumpers to the battery and the blacks to the engine block and NOT the battery. If you get large sparks, check your connections and you will just damage the cables and nothing else.
Regards,
Jim W
JWELK is offline
Smoke everywhere after battery dies!? 92yjwrangler YJ Wrangler Technical Forum 14 08-14-2009 07:58 PM
JK Jumping in 4WD LovinFirstJeep JK Wrangler Technical Forum 18 01-01-2009 02:08 PM
optima battery and smoke nothinguntil YJ Wrangler Technical Forum 11 12-23-2008 07:05 PM
Jumping out of 5th gear boatingncst8fan YJ Wrangler Technical Forum 11 12-13-2005 08:42 PM
4x4 Jumping 79SilverCJ TJ Wrangler Technical Forum 11 12-08-2005 11:51 AM
